Processing Speed- A Major Issue Nowadays
Recently I downloaded a heavy application on my laptop. At first, it did not take much time to process, but after some time, it started consuming a lot of time for processing. Sometimes it doesn’t even work a bit, and I have to exit it. What should I do so that I can run the application smoothly?
Answered By 0 points N/A #324537
If the application is of one or small-time use, prefer to use a laptop or computer with RAM higher than the previous one. If you want to process the application on the same laptop, try uninstalling some programs or software not currently in use.
This method should work and the application might start functioning appropriately. If this doesn’t work, you can try increasing the update speed in the task manager. You can even think of increasing the RAM of your laptop by adding additional RAM in the spare slots.
