Other programming language directory comparison with dos.
Hello experts,
Other programming language directory comparison with DOS. Can you give me the best information regarding Java, visual basic, c++ directory compared to dos? I just want to know how each programming language performs when in terms of directory issues.
Thank you.
Best Answer by
Answered By 0 points N/A #179722
Hello Ava,
Programming with DOS means that you do everything from the command line, and therefore it will be a bit hard when you have to work with codes that needs constant editing to correct mistakes. As for VB, Java and C++, you can easily transfer the code to an editor like the notepad or word and edit from there.
Nicke
Answered By 55 points N/A #179723
Hello Ava Larry,
If you want to know about the programming language then i am sending you an attached file in there you can get more than 10  different languages. And also you can get their usage in that file. All you need is to save that file and you have to open that file in txt document viewer. I hope that you can get the best from that file.
Java is a good one if you want to get a complete package in one language. It is a widely used language these days in the market.
