Need a DB power Camera app for Mac OS
So I have a DB Power Camera for Mac OS but unfortunately it came with no driver or installation guide or anything. I thought maybe I should be able to find the driver or application myself, but haven't been able to do so. That's why I am asking you guys if you can help me with a DB Power Camera app for Mac OS and also some instructions on how to install it, and run the software, because I am pretty new in this area.
Answered By 5 points N/A #174321
I was unable to find a manufacturer’s website for this camera. It appears to be a clone of the cameras made by this company. If you check that website you can compare the cameras to the one you have which should help you to match up the correct software that you need. To install the software, simple click the link provided and download to your computer. Open the app and follow the instructions until complete.
In regards to instructions, it is also possible to download a user manual which will walk you through the setup and configuration.
