Issues when “Show Startup Dialogue Box” was turn off
Our ITO under full Admin rights is using Autodesk Map 3D 2010 and everything works very normal.
It looks for files on the Autodesk CD and wants to reload part of the software, when normal user then tries to open ESRI ArcGIS 9.3.My operating system is Windows XP. See the following error message:
A work-around we found was to turn off the "Show Startup Dialog" box in the Options menu.
Please help me. Thanks in advance.
