I need a PPT convert to iOS app
Hi.  I would like to put a couple of PPT files on my iPhone.  Is there a PPT convert to iOS app that I could use to make it a PDF file?  I have the 64 GB iPhone 4S that has iOS 5.  Thanks in advance.
Best Answer by Kirk Strope
Answered By 0 points N/A #141059
As we all know iPhones does not support PowerPoint but it is actually pretty simple. Follow the steps below:
1.   Open your PowerPoint file, then click the office button located on the top left side.
2.   Go to Save As, then Find Add-ins for other formats.
3.   From there, you will find the Save as PDF or XPS add-in.
4.   You have to install that add-in.
5.   After doing that, you can now save your PPT file as a PDF files for iPhone.
 There is actually an application for IOS that converts any files. Its called Adobe CreatePDF for iPhone. Aside from PPT,this application also supports Word (doc and dcx), Excel (xlsx and xls) and images (jpg,bmp,gif,png and tiff).
Answered By 0 points N/A #141060
Hi
MS OFFICE PPT is a program used to create presentations. to convert ppt file to pdf try to install novaPDF you can convert your presentations into PDF files – simply choose novaPDF as a printer and once you click the Print button your presentation will be converted to a PDF. Having your PowerPoint presentation in PDF format is an advantage if you want to send it for review.
novaPDF is installed as a virtual printer so you can create PDF files simply by printing to it instead of your normal printer. To convert your Microsoft Office PowerPoint 2007 presentation to a PDF:
  1. Open Microsoft PowerPoint 2007 and go to Office Button->Open (or press Ctrl+O), browse for the presentation you want to convert to PDF and open it
  2. Go to Office Button->Print (or press Ctrl+P) and in the Printer section select novaPDF
  3. Before you create the PDF file you can adjust the settings for the novaPDF printer by using the Propertiesbutton
  4. Click on OK and choose the location where you want the PDF file saved. After the PDF is created it will be opened in the default PDF viewer
