I Can’t Install Dreamweaver cs4
I can't install Dreamweaver cs4 because it ask for serial number and I don’t have CD because I just only copy it from my friend and as I know he only downloaded it from the internet. Where I can get serial number?
Hi!
Your problem is quite tough especially if you are a beginner in software trouble shooting. But there are some advices that I'm going to tell so I hope it could help.
If the Adobe dreamweaver CS4 was just downloaded from any site, and if it’s just free, make sure that it has a valid serial key. Because when you are installing Dreamweaver or any Adobe softwares, it required to put the serial keys to install. You can ask your friend for the serial key. But if he or she persists, try to search on the internet. And if it doesn’t work, you must download a fresh copy of dreamweaver CS4 from the Adobe website and purchase a valid keys.
You don't have to be worried about being caught by the law for using counterfeited software, as long as you keep the updates and your antivirus software is active, you'll be protected. But keep in mind that most of the time, illegal softwares are usually defective, errors may come in. So if you have enough money to spend for it, just buy the original one.
I hope this was helped on resolving your issues.
