Hi, I am using a Win 7 laptop which I had bought from my friend, he had five drives each of 55 GB approx. So I want to Merge Partition Windows 7 drives A and C to get an extra storage space. Please help how to do it. Thanks in advance.
How To Merge Partition Windows 7 Drives?
To Merge Partitions Windows 7 you need to follow the following steps:
- Right click on My Computer and select Manage option.
- Click on Disk Management option.
- Select Drive A and click on Delete Volume to free up space.
- Now select Drive C and choose Extend Volume and then follow the wizard.
OR
Download Erase US partition tool or any other software and run it. Choose the partition to be merged and then click on the partition and then Merge Partition on the toolbar.
Now choose the partitions in the layout and assign the merge destination with a partition label. Click on OK and the program will check for free space and then click on Apply.
