How To Remove Ransom Virus To Prevent Your PC From Infection.
Every coin has two sides. Internet has helped but cybercrime is the con. Hackers use ‘ransom ware’ to lock your device, and demand ransom for the access. Prevention is better than cure. It is better to know how to avoid it. how to remove ransom virus?
Answered By 0 points N/A #200470
What is ransom ware?
  • It locks up your computer and you need to pay in order to access the system. From where does it come?
  • It is created by scammers. It can enter the PC through email or web browser.
How is it recognized that the computer is infected with ransomware?
When you cannot access your system, it is a sign that PC is infected.
How to remove ransom virus?
Your system is infected with a simple ransom virus, you can remove it by the methods use to remove malware. But if it locks up your machine you have to follow the following steps:
1) Restart your PC.
2) Press F8 key.
3) You will be redirected to ‘Advanced Boot options menu’.
4) Click on repair your computer and press enter.
5) Click on startup repair and let your PC reboot.
6) Your system is free from ransom now.
