How to find good php domain register script?
These days I am studying PHP programming language and collecting information about domain register. First I want to test with one extension and please tell me how can I find good PHP domain register script according to my requirement.
Best Answer by Schneider Matthew
Answered By 0 points N/A #150123
Halo Vincent Dubler,
I am giving you some page link where you can get PHP domain register script according to your requirement.
Link 1 : https://www.ait.com/support/script-library/
Link 2 : https://stackoverflow.com/questions/8481878/php-register-script-forcing-specific-email-domain
Link 3 : https://www.webdesign.org/
Link 4 : http://www.computersneaker.com/VOceZ/registration-form-php-script/
Make choice! You can try four no link. I think its will best !
REGARDS,
Washington Michael
Answered By 0 points N/A #150122
Hi Vincent Dudler,
Below is a link to a PHP code which has the capability to check availability of multiple domain names. You can specify the domain names in a text file and then run the code. It will check the availability of the particular domain name mentioned in the file.
Hope it helps.
