How to download bill format for cloth shop in PDF format?
Good day everyone. I would like to ask how to download bill format for cloth shop in pdf format? What are the steps needed for this kind of download? I would appreciate if you give me a step by step process for this. I'm looking forward for your answers. Thank you.
Best Answer by Hoffman Pero
Answered By 0 points N/A #152390
Assuming the bill you want to download is online then easiest way to get a PDF copy of a bill is to use a pdf printer. You can find both commercial and free software but for basic pdf printing you can use free software such as dopdf.
1. Download Dopdf
2. Install the pdf creator in a directory of your choice.
3. On your browser click file > Select Print > Choose dopdf from the listed printers.
4. Dopdf will prompt you to choose where to save the generated pdf > Make your choice then click OK. Dopdf will generate a pdf copy of the bill which you can then print if you want to.
Answered By 0 points N/A #152391
Hi, Mr. Ross Suominen.
There are plenty of ways to download your bill in pdf format.
You can find online or downloaded software to let them convert your files into pdf format. Just search pdf converter through search engines to help you find web sites offer free pdf conversion. Anyway, you don't have to do much work converting to pdf format. When the conversion was finished, web sites will let you now download the pdf formatted file and ready to print. Just make sure you have the pdf software. It also have a free download. You can find it on search engines, just download it and install to your computer. You can now open the file that you have converted. ūüôā
Hope this will you resolve you problem.
Best regards.
