How do I remove the remaining entries of Adobe After Effects?
I have errors involving Adobe After Effects CS3 installation. I had this software working for about weeks in my PC and there came a time that when I opened it, it asked me to contact my IT provider, or sort of like that. And now here's my problem: I tried uninstalling the software hoping to remove the errors and I was planning to reinstall it but even in the uninstalling process, it displayed the same message.
I can't seem to uninstall it so I tried using Adobe cleaners, but still didn't work. Finally, I manually deleted the AE folder from the Program Files and tried removing all of its shared components. I know I have to remove its registry entries so I need help in doing such. But you may know more about this, I'd like to have your opinions and suggestions for my problems. Thanks!
