How can set up an auto reply in MS-Outlook
Hello Friends,
I receive e-mails from a sender that shows the no-reply email address and sender name.
Yet, whenever I reply to the email, it voluntarily uses their client’s email address.
I figured that an auto reply through the use of a Rule and Alert will send back the email to the original sender, not to the client. I would like to set up an auto reply that sends to the client.
Will a "run a script" fix that issue or is there any other way to resolve it?
If “Run a Script” will fix it, how do I run a script?
Thank you.
