HD Pro Webcam C910 is not working in Windows XP.
Hi all,
I have bought a HD Pro Webcam C910. It functioned nicely at bad light. Sound quality is also nice. I used it on my home Pc which is running in Windows 7 operating system. Also I can use it in virtual engine that runs in Windows XP Pro 32 Bits.
Then I tried to used in my laptop that runs under Windows XP Pro 64 bits.
But why is it a message pops up that the version is not intended for my operating system when I used it in my laptop?
(The virtual engine runs on this, as a result the hardware is not responsible for this problem).
I went back to store, they checked and try to make it work, but no positive result.
Anyone knows what is the problem in my webcam?
Help please.
Thanks in advance
SMax4PNP.exe
This version of AudioESP is not intended For this Operating System
OK
