Having problems with DeepFreeze 5.0
I installed Deepfreeze 5.0 in my computer in 2007. It was functioning properly until recently. I tried to create a new partition on my computer, so I had to take down Deepfreeze for me to be able to create the partition. After some unknown cause the application collapsed.
I assumed that the program erased its data, but I was wrong because the .exe files still exist, and Deepfreeze continues to run in the background, but I think after the crash it caused an unwanted effect on my computer hard disk. I cannot close or stop the program. Please, I need the solution to this problem or I might have to reformat my computer, which is something that I wouldn’t want to do.
