Freeware converter for wma files to cda
I am looking for a good freeware to convert my wma files to cda so I can play some of the songs stored in my computer in my car stereo. My car stereo can only read cda files. Where can I download a freeware converter for wma to cda on the web?
Answered By 5 points N/A #195923
If you want to convert WMA files to CDA you can use Windows Media Player for burning CDA discs for playing in your car.
First you should do is to download latest Windows Media Player and open it. There you have library of all wma files that are on your computer. You can make a list with every track that you want to listen in your car. Then hold the shift key and click on the first and the last track in a list to select all the songs at once. When the track are selected go to burn button and choose Audio CD from dropdown menu. Make sure that you have inserted empty cd in your disk. Click Burn and Windows Media Player will convert your wma tracks to cda format.
Williamson Mellisa
