Free Software for Solving Algebra Equation in Windows
Where can I get an Algebra equation solution software download? My friend's kid is having some troubles in school and this might be helpful. A software that does not only give a solution but also gives the step by step process on how the solution was reached will be the best. Please let me know if you know of one or if you are using one, if it's good enough.
