Experiencing malfunction of Macromedia player
Last day I had no problem installing any games until this day, while installing a certain game an error occurred stating that the cd is validating and next one comes up with Macromedia player has stopped working. I did things I know that could help me fix up the trouble but sadly it doesn't work. Can someone please help me? I need the games installed for my internet shop.
Answered By 0 points N/A #80869
Here are options that could help you with your problem. Check first the application you're trying to run could be trusted and you have a good source from it. Now click the start button followed by clicking the right option which is computer menu, from this choose the properties option. Select system protection then click the advanced tab. From the performance section hit the settings and then the Data Execution Prevention Tab. It appears the two menus; turn on the Dep for all the programs. Now, click the add menu and bring the folder that your game is installed which can usually found in files folder of your program.
Click on the exe file which launches the application then you can now run your game. Another thing also; you might encountering a game incompatibility. To solve this one, go to the file of your game. Right click the shortcut then proceed to the property. Open the compatibility tab and mark the ''Run this program in compatibility mode''. Now, you have to try possibilities of choices among the drop box like the Windows 95, Windows 98 and so the others. Open the game every time you change it until you won't encounter the error anymore. Thus, this varies also the game you are playing.
