Drive letter for iPhone images
I wanted to know how can I make Windows so that I can create a drive letter for iPhone images. While connecting iPhone to Windows PC I am not able to find the new drive letter for it. I wanted to move the images to my PC with a single click on a letter. Can anyone help me in this issue.
Answered By 35 points N/A #167557
Hello
There is no need for manual tweak of your computer in order to use iPhone for sending pictures to windows machine. You can download and install this software: https://itstillworks.com/assign-drive-letter-iphone-14619.html
It enables you to access iPhone from computer with no problems. If you don't know how to use this application then you can install iTunes which are very easy to understand. I hope I helped you.
Regards.
