DesignStandard the setup must update files
The Design Standard software while installing asked for some updates and for a reboot if I click the OK button. I did so and nothing happened, I ran the install wizard again and the problem appeared again, downloaded the software again and still the same problem. Does anyone know how to solve this and why I have this error? Can anyone help me to run it properly? Thanks!
DesignStandard
The setup must update files or services that cannot be updated while the system is running. If you choose to continue, a reboot will be required to complete the setup
