Converting PowerPoint to flash PHP script
I am working on a project right now using PHP.
I would like to know about what is the best idea of converting PowerPoint to flash PHP script.
Is it possible?
If not, then what other alternatives should I consider?
Best Answer by Mckinney Ma
Answered By 0 points N/A #165077
I will show you two ways of doing this:
 First way:
 Open OpenOffice Impress
 Go to File > Open and open your PowerPoint presentation
 Go to export
 Export it as swf
 Second way:
 Save your PowerPoint presentation as WMF
 Import WMF file into Flash
 Export it as swf
Answered By 0 points N/A #165078
I will show different methods to convert Power Point file to flash files.
Method 01
Convert Power Point file to flash file through online file conversion
Website: http://www.zamzar.com/
Method 02
Download “Camtasia” to your computer & install it
(you can download this from www.techsmith.com)
1. Save PPT file as PPS file
2. Set Camtasia to record the whole screen
3. Play your Power Point PPS file & press F9 to record the screen
4. Then F10 to finish your screen recording
5. Finally save your screen capture in SWF format
Thanks & Regards
Mckinney Ma
