Café world run time error
Dear all,
I like to play games and now I am playing Café world. Till today I didn't have some problems with the game. But a few days ago a got runtime error 13. I have installed SP 2 on Windows XP. Could this be the reason I get error message?
Tnx
Maverick
Server9
Run-time error ‘13’:
Type mismatch
Answered By 20 points N/A #113665
Hallo Maveerick.
The error you are getting when playing the cafe world game is a windows runtime error and it could be caused by on of the following:
  1. Either the game is conflicting with TSR or another program that you are running on your computer.
  2. Or there could be a software issue with the operating system or the application itself.
  3. Or may your computer has been infected by a computer virus that is causing that error.
  4. Or may be your computer is running on low memory.
So just check your computer for these issues and resolve any if you find and you will be good to go to play your cafe world again.
Hope this helps.
__
Regards
Mahesh Babu
Answered By 590495 points N/A #310567
It seems that error is from a server. If the game you are playing is an online game, you probably need to check your internet connection if it is working. If your computer is connected to the internet from a router, try resetting that router.
If the router has a power button, press it to turn it off then unplug it from the power for about 10 to 20 seconds. Press any button on the router to drain any leftover power or to power cycle. After this, plug the router back to the power then turn it on. When the router is ready, open a web browser and visit a website.
Try clicking some links to verify your internet connection is working. Try playing your game again then see if it works. If this doesn’t work and you continue receiving a runtime error, try to uninstall and reinstall your game client. First, visit your game’s website and download the latest game client for your platform or operating system.
Once the game client has been downloaded, download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your game client among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer.
When it is finished, close Revo Uninstaller then run the game client installer you downloaded to install your game back. See if this works.
