Best program for hard resetting Smartphone device
Hello techyv,
What program resets smartphones? Or I mean what is the best program that can allow the user to reformat smartphones. I got my smartphone for almost five months ago, now the software seems having a problem. It will automatically turn off the device, then keeps on restarting all the time. I decided to turn it off for several days and as I check it now, still the same problem occurs. What will I do?
Expecting some help from you guys. Thank you.
