Antimalware prevent my VPN from running
Why is Malwarebyte anti malware pro blocking my VPN software from running? I installed the program about a week ago and the program is running fine. I later try to connect to internet through VPN and the VPN program is not working. Although I can connect to the internet and the connection is working fine, but using VPN is the issue. How can I fix this problem?
