Archive
Hi!
I am planning to buy a new scanner for my laptop. Can you tell me few information about this device? What are the pros and cons of using it? What are the specifications of this device? How much is it in the market now? What are the materials used to develop this device? What are the peripherals included in its packaging? What are the available ports for this device? What are the cords included in its packaging? Please assist me with these inquiries. Thank you!
Read more
Hello!
I want know what will be the best resolution if I need to scan a big poster with this device. I know that we need to do it by section or subdivide it into parts. Is there any way that we can do this systematically? That the edges of the sections can be matched and be automatically found if we are going to connect it like puzzle in any photo editing software? Please provide me  how am I going to subdivide this poster into sections or pieces that is based on the...
Read more
Hi!
My scanner keeps on disconnecting from my computer. I checked my connections they are all set. The port from the computer is quite dislocated and if I will wiggle the connector with it does move. Please give me instructions on how to place it properly and make it intact. With the USB cord I am using to connect this device, if you will look near to the edge of the connector, you will see a tampered part of the copper part of it. Can I still fix it or...
Read more
Hi!
I would like to purchase a new scanner for my laptop. Can you give me pointers on what to look and check for before buying it? What are the specifications of this scanner? What are the best features that it can offer? Does it come with photo editing software? What are the ports available for this? What are the peripherals included in its package? What are the pros and cons of using this printer? How much is it in the market now? How much will be the printer’s inks?
Read more
Hello!
Please give me instructions o n how to properly install this scanner. Please give me also the other connectors and options that I can use to connect it with my computer or laptop. What are the other uses of this scanner? Is it just a simple scanner or I extend it? Please provide me more information about the technology used to develop this device. If there's any software included with it, what is it? How useful is it in scanning pictures or documents?
Read more
Hi!
I have to always restart this scanner to make it work properly. After doing such step, it will continuously show blinking light and will not continue to scan any document. The part of the scanner where the plug is located, it is always hot. Could this be the cause of my problem or something else? Please provide me expert advice on how to resolve this issue, what are my alternative solutions that can be used, and what to do if this keeps on happening?
Read more
This scanner keeps on disconnecting even if it is properly connected while working. Please explain to me what are the factors affecting it and causing it? Does the glass inside this scanner or any scanner, what type of glass is that? If it's broken can I just replace  it with a  normal glass with the same thickness? Give me more information on the climate that it can hold. With extreme weather condition, does it also affect the performance of this device?
Read more
Hello!
Please provide me the benefits and features of this device. The material used in the development of the scanners. The warranty of this device, compared to its performance, is it enough and well covered or is it justifiable? The materials used, in the development of this device, will protect from objects or accidents? Or it is still a device that cannot withstand pressure or accidental bumps. Please elaborate more if I need to replace parts of the board inside, will I be able to get it from any local...
Read more
Hi!
I want to know if I can use this scanner both and laptop and desktop? What are the things that we need to prepare before we start doing this with the scanner? Provide us instructions on how to do this in our laptop and desktop? Provide us also other means to install it with our platforms? What is the difference of this scanner with the rest available in the market? The light used to capture the documents how does it work? Please explain it and simplify it.
Read more
Hello!
I just bought this scanner and I am thinking is it possible to use it in LAN connection? Is there any software that we need to install in our LAN network to make it work? Or is it just plug and play device? Provide us step on how to properly install it with our network area? Please give us also alternative ways on how to resolve this? Give us also other software that we can download from internet and to make this work in our network? Thank you!
Read more
