Archive
I have bee interested in the forex bit count and wanted to know the minimum hardwire requirement for me me get this going? Is there a way that I can run this bit coin on someone else's machine as in sharing tasks to ease and improve on performance? How much is the overall cost to setup this?
Read moreI have an Intel HD 3000 graphics card and wanted to improve on this hardware. Does this NVIDIA perform better than Intel? what is the cache level and memory allocated to the graphics of this card? Which ones is better in terms of price and performance ratios? I want to be able to do some graphics rendering .
Read moreI have a Intel HD 4000 card that has a slightly lower GPU and was in the process of buying a laptop and came across a laptop with an Intel 4500 card, Does this card have a dedicated memory and what is the core speed of this card? Does it support crossfire? What level cache does it support along with the main processor?
Read moreI have an infrared based phone and wanted to know what would be the range for the connection of this device with my laptop that is fully compatible infrared. How fast can I transfer data between the hone and the laptop given the fact that its a point to point connection? What security measures are there like the encryption?
Read moreHow many WPS connections can routers do at a given time? Is it possible to do a WPS based security connection to two devices simultaneously or is the connection alternatively? How safe is the WPS over the WPA encryption method and what may be some of the demerits of one over the other? I have noticed that many still use WPA despite the easier to operate WPS security.
Read moreI have a blender scene that I have imported from CAD as a stl file, How can I render this file to a unique resolutions say 600*600 dpi? I want the best quality for pictures so that I can display to one of my clients on my next meet. I would like to reduce the shadow effect on the object as much as possible.
Read moreI have a wireless adapter USB that I would want to reduce the transmission beacons, what would be effects to the network in terms of performance and power consumption for the wireless adapter? How can I then save on power due to connections on a wireless adapter? what is the best transmission of beacons or should I just choose the default? I want to be able to save on power when the adapter is no linking up to the network.
Read moreIn my area there are 10 wifi networks and I was primarily concerned about the frequency interface of the devices to other devices. Is it possible to change the frequency of a wifi network transmitter from 2.4Ghz to another value? How would you establish that another wireless signal is cause interference to your own network?
Read moreI have a Dlink wireless access point and is new to the aspect of networking, how can I create a wireless hotspot and hide my network to avoid it being seen by the nearby clients.? How many clients can connect to this device and how do I add new device to my access point if its hidden?
Read moreI have a RJ 45 cable that is unshielded, is there a way that I can shield this to avoid interference? I was made away of the shielded cables and their speeds are quiet fast, I would like to achieve these high speeds. Do I need to buy another or can I just use these cables but how can their speeds be improved?
Read more
