Archive
Hello experts,
My system had a message saying that time to update my Anti-malware. So I started the procedure to update my Malwarebytes Anti-Malware. Within few steps, I ended up with an error message. When I googled got some reasons for the error, hence I checked the internet connection to my knowledge everything is perfect. Where I am going wrong? Please help.
Title: Malwarebytes error code 732 (0, 0)
An error occured. Please report the following error code to the Malwarebytes’ Anti-Malware support team
Error code: 732(12029,0)
Read moreHey,
I see this error when I try to store data on a server. Its runs perfectly fine with local system I don’t get any error. This error in any way related to dll error. If it is dll error, do I need to re-install AIM? Re-installation might help me to fix the corrupted dll files. Friends suggest me some idea to overcome this error. Badly in help. Thanks.
Error
AIM.exe - Entry Point Not Found
The procedure entry point
?forcedLog@Logger@log4cplus@@QEAAXHAEBV?$basic_string@_WU?$char_traits@_W@std@@V?$allocator@_W@2@@std@@PEBDH@Z could not be located in the dynamic link library log4cplusU.dll.
Read moreHey Tech Professionals,
This is a wired error message getting whenever I try to initialize communication. Means whenever I try to login to communicate, ended up with an error. Don’t understand the root cause of this error? Please help me to find the solution for this problem. Your help is appreciated.
Title: Unable to initialize communications.
Critical error: Unable to initialize communications.
Read moreHello Pro,
My calendar is working well and I change whatever I want. But the problem triggered when I add an invite. And I also get the same error when I add a calendar to iCloud. It works within a limit of my access. Why this is happening? Does anyone know how to fix this error? Help please.
Error:
The server responded with an error.
Access to “Meeting with Mike Vaughn, Tim Cecere and Karen Campanella” in “Mike work” in account “icloud” is not permitted.
The server responded:
“403”
to operation CalDAVWriteEntityQueueableOperation.
Read moreHi experts,
I never experienced this type of error message, so having little hard time with this error. I used do this re-installations of printer drivers, for Windows 7 64 bit operating system it got ended up with an error. Deleted all files related to printer installation and also I do the system restore, but nothing worked out. Anyone experienced this error before? Help me to solve this error. Your help is great.
Error:
Novell iPrint
Error message: Unable to find a core driver package that is required by the printer driver package.
Error group: Windows
Error code: -2147021880
Read moreHi,
In the company they are trying impose the use of IPad in work. When I try import a theme reflecting company design I ended up with an error or warning message. Why I am not able to open the Keynote file? It is not damaged in my system everything is good there. I am able to open and view it. Help me to open it in my IPad. Your help is appreciated.
Error:
Keynote can’t open the file “KN Keynote.kth” because it is damaged.
Read moreWhen I try to connect to a printer in network, need to establish a connection first. But getting an error before it is connected. Error stated Connection has timed out, network and server is little bit slow and I am the authorized user, why I am getting error? I tried it again and again.Does anyone know how to fix this problem? Help please.
Error:
Message from webpage
ErrorCode: 10060
Error message: Winsock 10060 - Connection has timed out.
Error group: WINSOCK
Error code: 10060
Sometimes it get connected to the network but there the problem is different. Here the error message says...
Read moreHi Pro,
When I try to play the iTunes Radio, it’s giving me an error. For your information, I was signed in iTunes when I got this error message. So after this error message I re-launce the iTunes. But still I am getting this error. How to get rid of this error? Someone can help me please.
Error:
We could not complete your iTunes Store request. You are not authorized to access the requested resource.
There was an error in the iTunes Store. Please try again later.
Read moreHello friends,
Ares is creating an error which I don’t understand easily. I was about to create a folder with special characters and it throws me an error. And also when I try to create a new folder testAres, it failed to create one with an error. How do I create a folder? Friends help to solve this problem. Thanks.
Title: Creating folder ‘newFolder?testAres’ failed: 0
Read moreI purchased Prince of Persia: The Sands of Time but I can't seem to launch it. Every time I tried, nothing will happen except that it will show an error message: "C:WindowsSYSTEM32MSVCR100.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support." Error Status: 0xc00012f Can someone please tell me how to fix this? I am really eager to play the game, so please help me. Thanks.
Read more
