Archive
When I want to open a photo with Pain.net this error message appears and it says that the type is not recognized. I want to a open a JPG file, and I have tried to open all types of images and still the error. It worked fine before installing some new programs on my PC. I might have this error because of the new programs installed ? How can I solve this error ?
Thanks !
The image type not recognized, and cannot be opened.
Read moreHello friends,
I need this Microsoft Dynamics CRM Server in the computer when I am in process, I got an error message. The installation went almost to the end, but it failed leaving an error message. It says some tools failed and access denied. How to fix the issue? Friends suggest me some idea to overcome this error. Thanks.
Microsoft Dynamics CRM setup
Action Microsoft.Crm.Tools.Admin.ImportActivityFeedsAction failed.
Access is denied.
Read moreHello! I am new to Linux and I am really in need a Expert's help. Recently, I upgraded my Linux Mint 13 to Cinammon 14 and the error appears after upgrading when I clicked on the executables on the tar files. Can someone please help on fixing this? Thanks.
Could not display “/media/killswitchguy/New vol...inux Apps/eclipse(2)/eclipse”.
There is no application installed for executable files.
Do you want to search for an application to open this file?
No / ...
Read moreGoogle Earth suddenly stopped on working. I was Trying to install it and then it hangs and then I forced close it. When I opened it again, there is an error that appears on my screen. I already checked if the installation went successfully by checking if it's already on my Desktop or Control Panel, but it's not. I want to know how I can fix it and what are the troubleshooting steps that I should do to resolve this? I will really appreciate any help.
Google Installer
Installation failed with error 0x800703ee.
OK
Read moreHi all,
I am getting this Access violation error message when I work around the VSO Blu-ray converter ultimate. In the google search I am not able to find the solution. But I have installed NVidia graphics card with CUDA support in the system and also I updated the windows. Even after these changes I get the same error message. Please help me to resolve this error and to findsolutions. Thanks a lot.
Blurayconverterultimate
Access violation at address 00966154 in module ‘BlurayConverterUltimate.exe’. Read of address 00000004.
0K
Read moreHey,
I used to work a lot with SharePoint. Recently I am facing a problem in SharePoint. I created a SharePoint WCF service that uses Word automation service to convert documents to other formats. Sometimes the service fails abruptly without leaving a message. How to handle this situation? Is the problem related to configuration? Please explain me. Thanks.
Error
The security token request cannot be Completed.
OK
Read moreHello there,
I am getting this weird error message not able to install the Super Multi Blue Installer. The error message is totally wrong; I am installing the software in the LG BH08 device only. Do I need to check the drivers, but I haven’t made any change? What might be the problem? Please help. Your help is great.
This software can only be installed with a LG(HLDS) device. The set up will abort.
Read moreHi ally,
Whenever I start the computer I am getting this error message. The error message states that backgroundcontainerdll is not found in the computer. How to fix the dll in the desired location? Where to download the missing dll file? Please help me to resolve the problem. Thanks in advance.
RunDLL
There was a problem starting
C:UsersVentsislavAppDataLocalConduitBackgroundContainerBackgroundContainer.dll
The specified module could not be found.
OK
Read moreHello all,
When I try to install the Office Software Protection Platform I ended up with an error message. This error message is not allowing further steps, three options ends with the same error. For your information I have the trial version. Do I need to get the Office full version to avoid this error? Please help me to resolve this error. Thanks.
Setup
Error 1923. Service ‘Office Software Protection Platform (osppsvc) could not be installed. Verify that you have sufficient privileges to install system services.
Read moreHi,
I am beginner in Amos, just started to learn new concepts in details. I ended with an error message when I try to display a thumbnail in Amos. I have no idea why this happened. How to solve this error? I appreciated if any could solve my problem. Thanks in advance.
Amos
An error occurred while attempting to display a thumbnail for the file. Ex05-a.amw.
OK
Read more
