Archive
I downloaded updates for iPhoto through the App Store. It started fine and it took me few hours on playing around with my photos. This morning, when I try to open it again, there is nothing written on the screen except for the loading icon. I downloaded iPhoto Library Manager and run it thinking that it can fix the issue. But an error showed up. Please help me in troubleshooting this issue.
Error
Apple event timed out (‘core’/’getd’ (returnId 1) {---- = object specifier: {objectClass = ‘ikwd’;
Read more
I've just run the File Recovery process and after that, it prompts a dialog box as shown below. It stated that it fails to recover directory files. I don't know which one is it. So can someone please help me with resolving this issue. I need to complete the recovery process. Please help me.
EaseUS Todo Backup
Recovery completed. But failed to recover parts of the directory (files), or some sectors can not be written.
OK
Read more
Hi Expert friends,
I am just a beginner, having hard time with this error. When I try to access a file in the disk I ended up with an error message. The error states that file not found but there is the file in the disk. I can able to see it. Why I got this error if the file is available? I am confused, please help me. Thanks.
Exception
java.io.FileNotFoundException: C:UsersFujitsu User.netbeans6.7configPreferencesorgnetbeansmodulesuihandler.properties (Access is denied)
Warning
A java io.FileNotFoundException exception has occurred. However, the system should continue working without further problems.
Click show details for the stck trace.
Read more
Hi Professionals,
I am using Eclipse 4.2 on the computer, which had windows 7 64-bit operating system. When I try to edit a code in Eclipse, I stuck up with an error message. I tried restarting the system and restarting the Eclipse but nothing helped. Please help me to change the java editor to windows builder. How to change it? How to get rid of this problem? Please guide me.
Problem Occurred
Unhandled event loop exception
No more handles
Read more
Whenever I try to use Yahoo Messenger on my mobile phone, an error keeps on re-appearing. I have tried to reinstall the messenger for several times yet, when I opened it, the same error will occur. I'm not sure what to do next but I am keeping my fingers crossed that someone can help me on fixing this. Thank you.
Failed to execute last action (100)
OK
Read more
I don't know why I can't be able to start ichat. Every time I try to open it, an error will appear. I searched for some solutions online and already followed what they suggested such as removing the library prefs, reboot my modem and router and repair the disk permissions. However, nothing works so far. The error I've got is listed below:
An Internal iChat error occurred.
IChat couldn't connect to iChat Agent.
Quit
Read more
I'm running iOS 7.0.3 on my iPhone 4S. Recently, I have a problem with iMessage not activating. When trying to activate it, I received an error and I can't even sign in as I am having a connection error. I'm not sure how to resolve this anymore. Restoring my iPhone is my last option so I hope someone can suggest some alternatives to resolve this issue. Thanks.
IMessage Activation
An error occurred during activation.
Try again.
OK
Read more
While working with Cinema 4D, then I was notified with a patch upgrade. I clicked on Yes but it failed to open the file while in the middle of the installation. And then it suddenly quits. And now, I can't open Cinema 4D again and even throws an error message. Please tell me what to do with it. Thank you.
CINEMA 4D
Installation Error.
CINEMA 4D version (11.530) does not match Resource folder version (11.532)!
Please reinstall CINEMA 4D correctly!
Read more
Hi there,
When I open a project in NetBeans, I am getting an error message. It says that it cannot find the required web pages. Do I need to change the property settings? Please help me to fix the project properties and help me to browse the web pages. Is this a problem related with the installation? Any help would be appreciated. Thanks in advance.
Error
Webapplication1:
Cannot find the Web Pages folder ‘C:xampptomcatwenappswebapplication1web" Open the project properties and in the Sources category browse the correct Web Pages folder.
OK
Read more
I am using Swift 3d to import 3ds Max files. However, exporting from Cheetah 3d brings up an error. The total polygons I have on my object is 96,000 and I want to know if it's just fine since I am getting the error below. Please help me resolve this.
.3ds loader error!
There is a object with more than 65536 triangles or 65536 points. But the .3ds file format is limited to objects of that size.
OK
Read more
