Archive
Hello.Do you have a Gimp 2.6.x installation? You should have it, if you do not then download it. This error sometimes occurs if Gimp 2.8 find the old Gimp 2.6 dll.You need to do a search for libjpeg-8.dll and see what comes up. After that you need to Allow Gimp 2.8 to remove Gimp 2.6, or you can just delete it by yourself. After that is done, you should reinstall Gimp 2.6 and the problem should be solved. I hope that this helps.
GIMP Message
Saving 'C:zztempUntitle3.jpg' failed:
JPEG image plug-in could not save image.
Read moreHi Ally,
When I try to increase the work area in Illustrator, I ended up with an error message. What is mean by canvas size? I do not understand the error message. Someone please explain it detail, is it possible to increase the work size? How do I increase the size? Help please. Thanks a lot.
Adobe Illustrator
Artboard size cannot be bigger than canvas size.
ok
Read moreHi friends,
Recently I installed Picasa free download version in the computer. The installation went pretty well and good without any problem. The problem triggered when I open, it throws me an error message saying that it ‘is not supported on this system’. I have the basic requirements in the computer. What might me the problem? Help please. Thanks in advance.
You cannot open the application “Picasa.app” because it is not supported on this system.
Read moreHi folks,
When I try to open the Adobe Photoshop in the computer for the first time, I was stuck up with an error message. I tried several times uninstalling and installing the product but nothing works. Do I need to make any changes in configuration? I checked the license it is not expired. Please guide me. Your help is great. Thanks
Configuration error
Please uninstall and reinstall the product.
If this problem still occurs, please contact Adobe technical support for help, and mention the error code shown at the bottom of this screen.
Error 1
https://helpx.adobe.com/support.html
OK
Read moreHello Troubleshooter,
I got this error message while I am installing PES 2013 in the computer. Then I tried to reinstall it again but nothing worked, I am getting the error message repeatedly. Is that means the files are corrupted? How to fix the corrupted files? Please suggest me some ideas to overcome this error. Thank you.
ISDone.dll
An error occurred while unpacking: archive corrupted!
Unarc.dll returned an error code -7
ERROR: archive data corrupted (decompression fails)
OK
Read moreWhile I was attempting to connect to AIM account through iChat, a window dialog box appears with error message. And I can't connect to AIM. I don't know what's this error is all about as it saying about AIM socket error. How can I fix this? Can I fix it by resetting iChat?
IChat can't communicate with the Mac.com account
An undefined AIM socket error has occurred.
OK
Read more
Hello Pro experts,
I am completely new to Adobe, trying to learn slowly. While working in Adobe Illustrator I got this error message. The error state that the dimensions of this page are out of range. Is there any limitation in document? What is the maximum limit in Adobe Illustrator? Please support me find the solution. Thanks.
The dimensions of this page are out-of-range.
OK
Read moreSoundtrack Pro is giving an error after upgrading to Mac OS X 10.5 Leopard. And it became unusable. The error I am receiving is:
The application soundtrack pro quit unexpectedly. The problem may have been caused by the Instant Hijack Server plug-in.
Mac OS X and other applications are not affected.
Click Relaunch to launch the application again. Click Report to see more details or send a report to Apple.
Ignore / Report / Relaunch
What...
Read moreHello,
I bought a new SLR camera Nikon after taking pictures; I downloaded it on the computer. The problem triggered when I try to open a raw file from a camera. I have done all the update installation but still I get this error. I am not getting any kind of help from the link. Please help. How I can solve this error. Thank you.
Adobe Photoshop CS6
Photoshop cannot open this file.
If you are attempting to open a raw file from a digital camera, make sure you have the latest
Camera Raw update installed via Help> Updates...
If the...
Read moreHello folks,
I am an Adobe Photoshop lover I love to work a lot. Recently I got an error message while I try to crop an image. I have Adobe Photoshop CS 6 in Windows operating system. Everything else works well without any problem until now. Please suggest me some solution to fix this error. Thank you.
Error Title:
Adobe Photoshop CS6
Could not build the Crop preview because of a program error.
ok
Read more
