Archive
Howdy,
I encountered this error message when I try to install the IDT software package in the computer. The installation was aborted after the error message. The problem triggered while installing Audio driver so do I need to upgrade the driver. How I can solve this error? Please help me. Thanks.
Configuring IDT Audio Driver and Application
The hardware detected is not supported by this IDT software package. The install will be aborted.
OK
Read more
Hello. I have downloaded some plugins for my Gimp 2.6.11, but I am not able to use most of them. I have this project going on so I need to use a certain plugin.I am running windows 8 home .Every time I try to use a plugin, I get this error. Is anyone able to solve this. I am waiting for help.
An error occurred running python_fu_pattern_cubic. SystemError: new style getargs format but argument is not tuple
Read more
Hi tech experts,
I am getting this error message when I try to open a page from PDF document. I am new to Adobe, having hard time with this error. How to embed the PDF objects in the document? Please explain me in detail. Someone could help me to resolve this error and find solution. Thanks a lot.
Illustrator PDF: Warnings
The document contains PDF objects that have been reinterpreted:
The font Times#New#Roman,Bold is missing. Affected text will be displayed using a substitute font.
An unknown imaging construct was encountered.
OK Cancel
Read more
Hello Ally,
When I try to update the Adobe package, I did not face any problem while I update the Illustrator. The real problem triggered while I am updating the Cloud application I got an error message. I searched in the web for help; and I found that CC Cleaner tools helps to fix the error. Please explain me how to use it. Your help is great. Thanks.
Adobe Installer
We’ve encountered the following issues:
Sorry, there seems to be a problem with the installation process (Error code: A12E1). For troubleshooting tips, please visit our customer support page.
Cancel
Read more
Hi Pro,
I updated my Picasa 3.6 version to Picasa 3.8; installation was successful without throwing any error message. However, the problem triggered when I try the new face movie function in Picasa latest version. Is this the problem related to operating system? I do not understand the exact reason for the problem. Friends suggest me some idea to overcome this error. Thanks.
Error
This feature is not supported for Linux
OK
Read more
Hi expert friends,
I love this software; I use this to edit my videos. I am not a technical person I do not work in detail just do some editing. Earlier it used to crash rarely but recently it is happening often. This is very irritating to me, how I can solve this error. Please support me to find a solution. Thanks a lot.
Corel VideoStudio Pro
The program has encountered an unspecified error and has stopped functioning.
Please contact Corel Technical Support and send the dump file for analysis.
C:UsersAdminAppDataLocalTempvstudio_15.1.0.34_20130201_194528.DMP
OK
Read more
Hello Pro,
When I try to capture the video in Ulead Video Studio, I ended up with an error message. The real problem triggered when the press the stop button in the video capture, it throws an error saying ‘the file created is corrupt and unusable’. I get this error message even in the windows moviemaker too. I tried to trap the error, but I cannot. Help please. Thanks in advance. Please help.
Ulead VideoStudlo
Capturing failed.
The file created is corrupt and unusable. It will be automatically deleted.
OK
Read more
I received an error in transforming the BMP to TMX file. The error stated "A tile listed in Rules.txt could not be found. The missing tile is called "blends_natural_01_056. Please fix the invalid tile index or add the tileset if it is missing using the Tilesets dialog in Tilezed. (While reading Rules.Txt)."
Can someone please help me in resolving this? I followed the instructions on Thuztors mapping guide and changed the Rules.txt with older ones, yet it failed. This is from the Indie Stone game called "Zomboid". Please help.
Read more
Hi folks,
I get a weird error message from Adobe Photoshop, when I open it. I am getting this error message only the system upgrade. Now I have windows 2012 operating system. How I can solve this Application error? Do I need to reinstall? Please help me to fix the error. Thanks.
Photoshop.exe - Application Error
The application was unable to start correctly (0xc000007b). Click OK to close the application.
OK
Read more
Hello Tech experts,
When I try to send an email with attachment, I am getting an odd error message and I never experienced this before. I get this error message recently both in the desktop computer and laptop. Please help me with an alternate solution. Your help is great. Thanks.
Error
An error occurred trying to send your message. Please try again later.
OK
Read more
