Archive
Hi expert friends,
When I try to update windows in my computer, it throws me an error message. This error stopped me from going further in update process. It’s an individual PC not connected with network. No clue in the error message, anyone else has faced this kind of error message before? I don’t understand what is going on exactly. Very badly I need help. Thanks.
An error has occurred. In order to prevent and solve this error, we recommend you to connect your administrator
Read moreHi Ally,
I have been working on this Sony Vegas Pro project for quite long time. I never experienced this sort of error before. Little confused what might be worng, not able to figure out the root cause of this error. Opening the project and the .veg file every time when I start to work. Please help to find the solution. Your help is great. Thanks.
An error occurred while loading the project file Twentyfour.veg.
The COM object failed to initialize.
Read moreHello Brainy,
When I updated my Sony Vegas Pro build 511 everything seems to be good at the initial stage. But later on I started facing this error in 511 whereas in build 371 I never faced this problem. Which means this is not compatible in windows 7 operating? I may be wrong, do I need to re-install and try again? Please explain me. Your help is great.
An error occurred starting Vegas Pro.
An argument was out of its legal range.
Failed to initialize script host.
Read moreHi there,
At present I have MSE version 8 in my computer and it works well. But the error triggers only when I open a file which worked in old versions. Means if I open a file in version 1, error appears. I followed the instructions as per the error message, but no luck. Totally confused, please help me to solve this problem and guide me in right path. Thanks.
Expected MSE format version 8
To convert files made with older versions of Magic Set Editor:
1. Download the latest version 1 from http://magicseteditor.sourceforge.net/download
2. Open the set, then save...
Read moreHi Experts,
When I try to install the AutoCAD 2012 in the computer I stuck up with an error message. I am not able to proceed with the installation, error message stopped my installation. I checked the system capacity and it also compatible with windows operating system. And I have the permission to add a new program then what might be the issue? Please help.
The installation is forbidden by system policy. Contact your system administrator.
#1
Read moreHello Whiz,
The TZAC download and the installation went well and good without any problem. The problem is when I try to run or play the game, the error appears. I searched for some solution to fix the problem but not able to find one. I created the shortcut as it mentioned in the error message, but still the problem remains. Please help me to fix the error.
Couldn’t parse command line options. Please note that you have to set a game ID in a shortcut. Please either use predefined shortcuts or check the website for information...
Read moreHello Ally,
I am a beginner in .NET, When I tried to install the Microsoft .NET Framework 4.0 I ended up with an error message. For your information it is a licensed version not the pirated one. And I have windows 8 operating system 64 bit and 250 GB Hard disk. I tried the options in the error message like rebooting the system, closing other applications and restarting the installer again. But no luck guys please help. Your help is great.
An error occurred while installing the Microsoft .NET Framework 4.0 (DN -2145091572). Reboot your computer, exit...
Read moreHi there,
When I try to update the SpywareBlaster in my system, I ended up with an error message. The error code is ‘U003’ it states that error in downloading the database files. I checked the following things mentioned in the error, it has access to the internet and nothing is disabled to my knowledge. I don’t understand where I went wrong. Please help me to solve the problem. Thanks.
There was an error downloading the database files. (Error Code: U003)
Please make sure that SpywareBlaster has access to the Internet, and that you have disabled any proxies...
Read moreHi there,
I like this DivX player, it is amazing to watch movie in DivX. So I download it and installation also went pretty good. But when I am about to launch it, I ended up with an error message. As per the message I reinstalled it again thinking of this might solve the problem. But nothing changed I am getting this error again, Please help. Thanks.
C:Program FilesDivXDivX Plus PlayerDivX Plus Player.exe
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
Read moreHello friends,
I am in the process of setting up my new system, during the program files setup I got this below error message. I have windows 7, 32 bit and 250 GB hard disk, 4GB RAM operating system. Simply I don’t understand what I have to do now? Please help me to fix this error. Your help is appreciated. Thanks.
ShellExecute failed (2): Is this command correct?
“C:Program Files (x86)Notepad++.exe”
“G:ScriptsPurge.bat”
Read more
