Archive
Hi-ya,
I am working in Teamwork using hotlinks for quite long time. But some time very rarely I am seeing this error on and off, after a while it work fine again. The connection with the server is perfect; I don’t see any other error. What might be the root cause for this error? Please suggest me some ideas to get rid of this error before any damage. Thanks in advance.
Error occurred during the last Teamwork operation!
Server returns error code!
Read more
Hi Whiz,
I am getting this wired error message while I am working with AutoCAD. This error is bothering me so much, not able to continue with the work. I googled and tried some solutions like reinstalling, and restarting the system and also even I tried to repair it. If the problem is in the card drivers, how do I fix it? Help me to fix the card. Thanks in advance.
FATAL ERROR: Unhandled Access Violation Reading 0x0040 Exception at 401f19beh
Read more
Hello friends,
When I try to download the Xcode it went pretty good. But the error triggered when I tried to set up the xcode. The error states that ‘an error occurred while extracting files’, for me it seems there is no problem with the download. So tried to repeat the download process and reinstall again, but luck I got this error again. Please help. Your help is great.
The application could not be downloaded.
An error occurred while extracting files from the package “mzm.dsqyrssa.pkg”.
Read more
Hi experts friends,
When I try to install the Adobe InDesign CS 5.5 I ended up with an error message. The installation is stopped right there. The error message states that dll is missing from your computer. Where do I find the missing dll? Can I able to install the dll file separately? Help me please, thanks.
The program can’t start because xerces-c_3_0.dll is missing from your computer. Try reinstalling the program to fix this problem.
Read more
Friends I am new to PS3, don’t know much about the function and operation. I am getting this error in PS3 don’t understand the problem and how to solve the error. I used the Serviio before long back, but never experienced this error in Xbox. How to solve this error? Is the Serviio is compatible with PS3? Do I need to upgrade? Please help. Thanks.
C:Program Files (x86)Serviiobin\..lib/ffmpeg.exe -i E:Almost Heroes.mkv -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:WindowsTEMPServiio is not accessible.
The filename, directory...
Read more
Hello experts,
Accidently my system is crashed, so I used the Symantec System Recovery to recover the data. When I attempt to create a recovery disk using the Symantec recovery I ended up with an error message. I need help very badly, its urgent too. I don’t understand the problem and error message. So please guide me to fix the error. Your help is great. Thanks.
Error creating the custom recovery environment.
SavingSession
ECA307DE
Error ECA307DE: Failed to unmount a previously mounted WIM file. A process or application may have a lock on a file within the mounted WIM content....
Read more
Hello friends,
Friends I need help, I got a new blackberry phone and I have the software to connect with the system. But I am not able to connect the device with the system through the software. It throws me an error with three options either to retry or repair neither cancel the process. I tried all the options none of them works. Please suggest me some solutions. Your help is appreciated.
The BlackBerry® Desktop Software cannot connect with this device.
If this device is rebooting or has dead battery, click Retry to attempt to reconnect once the...
Read more
Hi friends,
When I am working with the App-V to launch the application, I get some errors. I tried some of the general methods like restart the application and launch the application again. But nothing solved my problem, the error remains the same. Through internet search I came to the point ‘environment variable configuration’. How do I configure the variable? Please help. Thanks.
The Application Virtualization Client could not launch the application you requested.
The application name you specified is ambiguous. Use the full name and version for the application.
Error code: 461758B-0B211304-00000C15
Read more
Hi Pro Experts,
When I tried to install the QuickTime player in my system, I ended up with the following error message. I am not able to continue with the installation further. For your information I have windows 8 operating system, 64 bit and 250GB hard disk operating system. I am a good movie watcher, the VLC media player is working without any problem. How to solve this error? Your help is appreciated. Thanks.
Could not open key: UNKNOWNComponentsDA42BC89BF25F5BD0AF18C3B9B1A1EE868AB67CA7DA73301B7449A0300000010.
Verify that you have sufficient access to that key, or contact your support personnel.
Read more
Hi expert friends,
When I signed in Microsoft Lync 2010 to schedule an online meeting I ended up with the error message. I am not able to set the online meeting. After the error message I checked the account user but I don’t see any problem there. What is mean by UC enabled? It’s my account then what might be the issue? How to fix this error? Help please.
You cannot schedule the online meeting because you are not UC enabled or there may be issues with you Communications Server account. Make sure you are signed in...
Read more
