Archive
No recovery policy is the main error now. I have this error since yesterday and I was hopping maybe it will disappear because I don’t know how to solve this one. Can you help me to fix this error? Please tell me what is causing it and what recovery is talking about?
Thank you!
NO RECOVERY POLICY
There is no valid encryption recovery policy configured for this system. (0x1773)
OK
Read more
Hi experts,
While my PC was opening this error appeared on my desktop. I verified all my startup programs and the folder is empty. I did a small search on the Internet and nothing useful was found. Does anyone have any idea about this error? How can I solve this, please help me!
Thanks!
Launcher Error
Failed to load the launcher DLL:
The specified procedure could not be found.
OK
Read more
When I want to open this application this error appears on my desktop and it appears every time I click on shortcut to open the program. I never experienced such an error before and I don’t know how to solve it. Can you guys help me to solve this? You know what can be the main cause?
Thanks!
RPC_S_WRONG_KIND_OF_BINDING
Error Code 1701. (0x6A5) The binding handle is not the correct type.
OK
Read more
Using the Update Manager I found some available software updates. Now when I want to install them an error window appears and warn be about the errors. The Update Manager is the only way that I know how to make an update on everything. Please tell me why I have this error window and how I can install the updates properly?
Thanks!
Windows Script Host
Line: 1
Char 27
Error Unterminated string constant
Code: 800A0409
Source: Microsoft VBScript compilation error
OK
Read more
Hello experts,
When I try to open Live Gaming with Halo 2 I am getting this error. I don’t know now is not working because last time when I played the game online it worked just fine. I have reinstalled the game twice and I still have this game error. Can anyone tell me please why I have this error and how can I solve this so that next time won’t appear again?
Thank you!
Cannot allocate required memory. Some other application has loaded where Halo needs to be located.
OK
Read more
Hi there,
After I made the update of my Windows 8 to Windows 8.1 I got this error on my desktop. If I click OK the error appears again and again. I don’t have a solution for this and I also don’t know why I have it. Can anyone in here help me to fix this? I have this error because of the update?
Thank you!
Administrative Templates
Resource $(string.AdobeReaderX) referenced in attribute displayName could not be found.
File C:windowsPolicyDefinitionsUserExperienceVirtualization.admx,
line 94, column 236
OK
Read more
I had this fatal error during the installation of Java. I don’t know why could cause this error and how can it be solved. Please experts can you help me to solve this fatal error ? I have to say that I just cleaned up my PC because I had some viruses and I think that might be the problem. Thanks!
Feature transfer error
Error: -1603 Fatal error during installation.
Consult Windows Installer Help (Msi.chm) or MSDN for more information
OK
Read more
I have installed SegSvr 32 to install and register some DLL file on my Windows XP (X32) and when I want to run it this error message prompter on my desktop. I tried to reinstall the program, but this error continues to appear. Please help me to install this properly and tell why I can’t install the DLL files without getting any error.
Thanks!
RegSvr32
The module “ieframe.dll” was loaded but the call to DllRegisterServer failed with error code 0x80004001.
For more information about this problem, search online using the error code as a search term.
OK
Read more
This morning when I opened my PC this error popped-up. I made some search but I found nothing, I tried to search for the missing DLL file but nothing found. The problem is that I have this error every time I open my PC. Can anyone please tell me how can I fix this? Why I have this error?
Thanks!
Message
IQ dll not found. Is DTN IQFeed installed?
OK
Read more
Recently I added a new email account to Outlook and after I did all for the new account this window appear and I am stuck with it because I don’t know what happened. I clicked Deny button because I am afraid that something will happen to my current account if I click Allow. I need someone to tell me what this means? If is bad or not and please help me to set up a new email account in Outlook.
Kind Regards!
Microsoft Office Outlook
The Add-in “AVP MailChecker” (C:Program FileseScan AVP MailChecker.dIl) cannot be loaded...
Read more
