Archive
I am getting this error “Could not obtain a license for SolidWorks Standard” after I upgraded my machine to Microsoft server 2012. I was in the assumption that the licensing was not upto date and I tried updating the license manager with no luck. I looked at the license borrowing table of the license manager to find a couple of licenses there. Still wondering why this is failing. Can anybody here help me on this? Help will be greatly appreciated. Thanks.
Could not obtain a license for SolidWorks Standard – License server doesn’t support this request....
Read moreHello trouble shooters,
Something went wrong and some application crashed. I am in the situation to format my system, after that I do re-installation of all the software. But I faced problem only with this After Effect, got an error message in the initially setup. Not able to continue further, after effect has crashed. Does anyone know how to fix the problem? Help is appreciated.
After Effect can’t continue: sorry, After Effects has crashed. See https://www.adobe.com/support/products/aftereffect.html for known issues. If you still can’t resolve the issue, please contact Adobe Technical support (2).
( 0 :: 42 )
Read moreHi,
I am a beginner; don’t have much knowledge about system errors and solutions. I don’t know to explain this error, so attached the screenshot of that error message. How to find the root cause of the error? Any bug in the application? How to fix it? Friends help me find the problem first, also the solution. Thanks.
Could not complete your request because "", an internal component, is missing (-20008). Call Digi for a secret decoder ring.
Read moreHi tech gamers,
I am gamer too , like to play games a lot. When I am trying to install the Roxio game I got stuck up with an error message. I am not a technical person finding hard to track problem. The setup failed in the intial stage, like I didn’t selected the language. What I have to do now to install the game? Your help would be great.
Error attempting to read from the source install database:
D:CPDECODERPACK_GAME1XCPDP.msi
Read moreHi experts,
I am beginner in ASP.net, trying to learn new concepts daily. Like that when I am trying to deploy a website on my local machine. I experienced this error, anyone else have experienced this type of error in the past? Am I missing any document? How to resolve this error? Any suggestion would be appreciated. Thanks for your help.
not well-formed (invalid token) at line 1 of profile0.xml
Read moreHello friends,
When I try to boot the system from USB flash drive, needed this WintoFlash. I made this information ready to run the WintoFlash. But I got up with this error message. Don’t know where I went wrong? Do I need to send mail to support team? Anyone has experienced this problem before? Please help me to find the solution.
NovicorpWinToFlashDLP_NotFound
Read moreHi all,
I get this error message in Visual Studio 2008 custom installation. I am not aware of where could be the problem? I have a doubt whether the installation is corrupted. How to find the cause of the error? I am beginner, so getting tired easily because of this problem. Help to fix the error.
Error 1001. Exception occurred while initializing the installation: System.IO.FileNotFoundException: Could not load file or assembly 'file:///C:Windowssystem32Action' or one of its dependencies. The system cannot find the file specified..
Read moreHello Pro,
The share operation could not be completed because of this error message. I don’t get the problem? Chapters are set with enough distance, it have both the beginning chapter and the end chapter. Why I am not able to complete the operation? I am not aware what is going on with this error? Help please.
The share operation master file has failed
The operation could not be completed because the chapter marker trach could not be written (error – 12769).
I got a new notebook and I want to set some good application in it. So I tried to connect to WiFi to download some application. But it throws me an error message ‘invalid setting’ and it could not start Hotspot. Why I am getting error? I checked the WiFi settings, it is on and enabled. Please help me fix the error. Thanks.
Could not stop / start hotspot because of invalid settings:
Wi-Fi is disabled. Press Fn+F2 to enable, or move your Wi-Fi’s toggle switch to on
Read moreHello Tech Pro,
It’s very hard me to explain the error in words, so I attached the error screenshot. Image speaks more information rather than words. After the error googled, found lot of different problem but no luck for me. Thinking is there any problem with the source footage or operating system not sure. Please contribute your suggestions. Thanks.
[/Volumes/BuildDrive/Codname64/pro/ext/adobe/MediaCore/Backend/Make/Mac/../../Src/Sequence/TrackItem.cpp-161]
Read more
