Archive
I installed Fuse 2.6 but cannot get it to start. Every time I try opening it I get the following error. I just got the amp today so this is the only version of Fuse I have tried.
I'm running Win7 x64 which exceed the required hardware specs. I also have Microsoft.NET Framework 4.0.30319 and Microsoft Silverlight 5.0.61118.0 installed. Have any idea to handle this? Thanks in advance.
Error Message: Error parsing C:WindowsMicrosoft.NETFrameworkv.2.0.50727confimachine.config Parser returned error 0xC00CE556.
Read more
I have received an error upon windows starting up in Windows 7, Error code: 0×80070002. Have any idea to fix this problem? Any help would be really appreciated. Thanks.
Error Message: An error has occurred in the program during initialization. If this problem continues, please contact your system administrator.
Error code: 0x80070002
Read more
 Access provides a number of error messages, but many are confusing to the users. I find it sometimes useful to replace the system error messages with custom error messages. The Null primary key is a case in point.
When I try to leave a record on a form without a primary key value, the form will display the following error message. I am very upset how to resolve this issue? Help me to resolve this problem. Thanks.
Error Message: Index or primary key cannot contain a null value.
Read more
Hi experts,
When, I open Notepad and type in it while Pro Tools is playing. It appears that Pro Tools thinks Notepad is a part of its own programming and tries to get Notepad to access DAE.dll. Guess there is some quirky "focus" "calling" going on in Pro Tools. Notepad kind of seizes up, but works okay after a few re-focuses. How to fix it?
Thanks in advance.
Error Message: This application has failed to start because DAE.dll was not found. Re-installing the application may fix this problem
Read more
I have some serious problem using XenApp. When I started to use this app on form it said “Notepad” failed to start”. I got the following error message. I tried again to resolve this matter but the server is not able to start this application.  Any help would be appreciated.
Error Message: “Notepad” failed to start. The Citrix server is unable to process your request to start this published application at this time. Please try again later. If the problem persists, contact your administrator.
Read more
Hi experts,
After installing 6.0, each time running Notepad++ I get this error message. I tried the latest version to fix this issue but can’t find any result. Help me.
Error Message: This version of NppExec requires Notepad++ ver. 5.1 or higher
Read more
I am currently using Dell Inspiron N7010 Windows 7 x64. A couple of weeks ago when trying to use Skype video call, it came up with an error message saying webcam could not be found. Neither the Webcam Central nor the webcam itself would operate. I have decided to reinstall the application but did not happen anything. I extremely need your help. Thanks.
WebcamDell.exe has stopped working
A problem caused the program to stop working correctly. Please close the program.
Read more
When I try to edit a file in COOL Webtop I get the following error message. I tried many times to resolve this error by searching but could not find the solution. I extremely need your help. Thanks.
The document name or path is not valid. Try these suggestions.
*Check the file permission for the document or drive.
*Use the File Open dialog box to locate the document.
(C:DocumentumCheckout3-04.doc)
Read more
Hello experts,
After updating iTunes on my MacBook Pro (OS 10.7.5) the iTunes store hasn't been loading properly. I am currently using iTunes 11.0.2, but it worked just as crappy with the previous version. I searched solution online but I could not find. I just want to remove this creepy error using your suggestion. I really need your help to resolve this matter.
Thanks in advance.
Error Message: We could not complete your iTunes Store request. An unknown error occurred
(-1202). There was an error in the iTunes Store. Please try again later.
Read more
Every time when I want to activate Genius in iTunes 10.5 I get an error message.
It called (-42092), but which error is this? I don’t find any information in the internet. Any help would be appreciated. Thanks.
An unknown error occurred (-42092).
Read more
