Archive
Every time I wanted to install, it ends with this! I have changed o/s, but still no results.
Is there any solution? Any idea would be greatly appreciated. Thanks for all.
CorsixTH encountered an error during startup – consult the log window for details.
OK
Read moreHello,
I was using an old version of GPU-Z (0.3.4) until this morning. I decided to upgrade to the latest version (0.3.7) and now I get this error message. When I click Ok it opens up another error message.
Anyone else get this? Help me. Thanks in advance.
GPU-Z
Could not install driver. The specified service has been marked for deletion.
OK
Read moreHi,
I was checking for updates on the web using Eraser interface, the application displayed an internal error. Can you provide me the proper solution step by step to resolve this issue? What should I do to fix it? I really need your help to fix it. Thanks.
Eraser
Value of ‘-21500’ is not valid for ‘Value’. ‘Value’. ‘Value’ should be
Between ‘minimum’ and ‘maximum’.
Parameter name: Value
OK
Read moreHi,
Eraser; requires elevated privileges. What is the elevation? How can I fix it? Can you provide me the step by step solution to resolve this issue? Thanks in advance.
Eraser Shell Extension
An error has occurred:
The requested operation requires elevation.
OK
Read moreHi experts,
I downloaded 3DMark 06 and went to run it, all is fine, I start benching, and then like half way through I get this error! Does anyone know what the problem might be? My specs are in my sig, and I am pretty sure my drivers are all up to date. My current drivers are:
Installed Drivers nv4_disp (6.14.10.8198 - nVIDIAForceWare 81.98)
Any idea would be appreciated. Thanks for all.
3DMark 06
IDirect3DDevice9: Present failed: Device lost (D3DERR_DEVICE LOST)
OK
Read moreHello,
Origin has encountered a serious problem and must close.
The problem noted in the title happens just after I have logged in. I've tried to uninstall Origin completely and reinstall it, but the issue still remains. I really need your help. Thanks.
must close
Help improve Origin by submitting data about this crash.
Crash report details
Send crash report
Restart Origin Exit Origin
Read moreHello,
I am getting the following error message while trying to register a nexus 1000v plug-in and I find this error. Don’t know what to do. Please help.
Installation details:
ESX 4.1
Vsphere 4.1
Nexus 1000v 1.3a
I have nexus VSM and download XML from http://"Ip VSM"
Thanks for all
Error
An internal error occurred in the vSphere client.
Details: Invalid URI: The URI is empty.
Contact VMware support if necessary.
Report Error to VMware…. Close
Read moreHello,
I have done Migration old report to new Nexus 2.3.0. and encountered this error. How to fix it? Any help would be really appreciated. Thanks in advance.
Error
The server encountered an unexpected condition which prevented it from fulfilling the request
Nexus returned an Error: Error 500: Server Error
OK
Read moreHello,
I just tried using Launchy to Copy with the latest V2 of UR, importing a web page from Firefox via Launchy (I used the copy command provided in the XML script, at: https://www.kinook.com/Forum/showthre...?threadid=1336-(Samplesite) doesn't work, and causes an access violation too...
Is this because the Launchy XML is wrong for V2 - or is it because there are some general errors by importing in V2, as I and others have experienced repeated access violations using V2? Help me to fix it. Thanks.
Read more
Hi experts,
In the Command Browser, when I try to "import" a saved "MyCommands.XML" file (which had I saved using "export" and selecting the .Xml file type), I get the error. Since I didn't also save my commands as a .DAT file, if I can't import the .Xml file, I am faced with recreating all the exported commands. Any suggestion would be really appreciated. Thanks in advance.
Read more
