Archive
I tried to uninstall EaseUS Todo Backup but I can’t seem to do it (please check image below). I went to the Control Panel, to the add/remove program options but to no avail. What do you think causes this? Is there any way that I can remove the mentioned program?
Thank you and god speed.
Error
C:Program FilesEASEUSTodo BackupbinAgent.exe
An error occurred while trying to replace the existing file:
DeleteFile failed; code 5.
Click retry to try again, Ignore to skip this file (not recommended), or Abort to cancel installation.
Read more
Hello everyone!
I got an error while I was installing Microsoft Dynamics CRM 2011 on Windows Server 8. It seems to have something to do with Windows Indexing Service, but the thing is, this service is not available anymore for this server. Do you have any idea what’s going on? Please help me find a fix.
Thank you very much.
Action Microsoft.Crm.Setup.Common.InstallHelpIndexesAction failed.
Retrieving the COM class factory for component with CLSID {3BC4F3A1-652A-11D1-B4D4-00C04FC2DB8D} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
Read more
I tried to install MSSP SDK but I was not able to. This error popped-up and have no idea what this is. Someone please help me.
Error writing to file:
Microsoft.Speech.Tools.AppDev.Common.dll.
Verify that you have access to that directory.
Read more
Good day to you all.
I have the Ask Toolbar and have decided to remove it. So I went directly to the toolbar because it has an uninstallation option in it. But I somehow received this error message. Please help, there is no other uninstallation option that I can find to remove this. I would want a clean uninstall.
Thank you.
Setup
Unable to execute file:
C:Program Files (x86)Toolbar Uninstallertbu.exe
CreateProcess failed; code 740.
The request operation requires elevation.
Read more
I have Malwarebyte’s Anti-Malware solution. As usual, I thought that I should have its latest version update, which is at 6/1/2011. This is where the problem set in. I started receiving an error code (lease see below). And I tried to fix this with a troubleshot when I received another message, “Can't Find DLL Entry Point, GetConfigParameter in mbamnet."
My computer is Dell Studio XPS running on Windows 7. I tried doing all this carefully. Can somebody help me on this?
Thank you very much in advance.
Malewarebytes' Anti-Malware
Error ‘453’:
Can't find DLL entry pointGetConfigParameter in mbamnet
Read more
Greetings!
I was trying to download Trend Micro Housecall when I received this error code/ message. I tried it again in safe mode. I looked for some sort of data corruption or virus in my computer, but still to no avail. My internet connection should not be a problem because it’s working just fine. I am to my wits end. Please, I badly need you advice.
Trend Micro HouseCall
Unable to complete the download.  Please ensure you have Internet connection and try again.
(E:1154046295:0)
Read more
I loaded the TV Server installation and I had this error message suddenly popping up. It only happened after the installation of SQL Server that I did. Is there a workaround on this? I’d appreciate a reply.
Thank you so much.
MediaPortal TV Server / Client Setup
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86) is not installed.
It is a requirement for MediaPortal TV Server / Client.
Installation will be canceled.
Do you want to get more information about it?
Read more
Hi all,
In SharePoint, I tried to open a document when it suddenly failed on me and I got this error message:
The instruction at "0x30cb0c0f" referenced memory at "0x00000000". The memory could not be "written".
Click on OK to terminate the program
What do you think is going on? Is there a way to have this fixed?
Thank you for reading and hope to hear from you soon.
Read more
Greetings.
I am having issues after an installation of MS Office Project 2007. Some people said that there are problems after its installation; that it has some kind of compatibility issue with Microsoft Office 2003. Is there truth to this?
Please do share. I’d be very grateful!
Read more
Good day to you.
I was trying to install MS Project Standard 2010 when I got an error code.
Error 1920. Service 'Office Software Protection Platform' (osppsvc) failed to start. Verify that you have sufficient privileges to start system services.
How do I fix this? Please feel free to share your thoughts.
Thank you so much.
Read more
