Archive
I am getting the following VMware VCenter Converter error due to incorrect user credentials.
What is actually wrong with the server connection?
The ports the working fine then why this error displayed?
I can’t complete my operation so please give some suggestion what to do now?
Any help would be greatly appreciated.
Thanks in advance.
VMware v center converter the operation could not be complete
VMware vCenter Converter
The operation could not be complete for ‘172.20.2.2’ due to incorrect user credentials.
Read more
I received the following error message when I was trying to convert a Remote machine using v Center Converter agent deployment. What should I do now? I need your suggestion to resolve this issue as soon as possible. Any help would be appreciated. Thanks.
VMware vCenter Converter agent needs to be temporarily installed on the remote source machine
VMware vCenter Converter Agent Deployment
VMware vCenter Converter agent needs to be temporarily installed on the remote source machine 172.20.2.2.
Uninstall VMware vCentre Converter agent
Automatically uninstall the files when import succeeds
I will manually uninstall the files later
Read more
Hi experts,
Why am I getting this following error message when I try to connect to a Microsoft Windows 2000 computer over the network? Is there a server problem or something else? I really need your assistance. I have searched online for a solution. I need your suggestion. Please help me. Thanks for any assistance.
VMware Workstation Unable to connect to the network share ’72.149.26.69ADMIN$’.
VMware Workstation
Read more
Recently, I downloaded DVD Fab connected to the internet and when I attempted to install the setup an error message displayed. Now I am trying to resolve this issue with many ways but I can’t do it without an expert’s advice. Please suggest me the proper instructions. Thanks in advance.
Allow DVDFab to access the internet.
DVDFab
DVDFab is going to check if there is a new version.
If you have firewall software installed, please configure it to allow DVDFab to access the internet.
Read more
I have to create a new website for a client abroad. Currently I am using Adobe Fireworks (Fw). While saving the file in my system an error was prompted to me saying that “Could not save the file. The file was not found.”.
How do I save my file now? Is there any other way to solve this issue?
Read more
As I was checking my company’s system an unexpected error occurred saying that it “Failed to retrieve connection information. Try to login again.” Can anyone help me with this?
I really need to access the database for me to produce some query needed by the company as soon as possible. TIA.
Database Manager
There was an error connecting to the server.
Failed to retriece connection information. Try to login again.
Read more
As I was trying to create an applet for school Java suddenly crashed. The error message “Cannot launch java application Uncaught exception in main method:Java.lang.NullPointerException” was produced.
Should I reinstall Java or is there a quick fix for this issue?
Cannot launch Java application
Read more
As I was trying to upgrade/update my Virtualbox an error occurred saying that it had terminated unexpectedly during startup. Beforehand, I have tried to download an upgrade of the software. What is the quick fix for this? I have posted here the complete error message.
Thanks in advance for the solution you will be suggesting.
VirtualBox- Error
Failed to open a*ssion for the virtual machine OEL5.U4.WLS1Ig.
The virtual machine 0E15.U4.WLS11g’ has terminated unexpectedly during startup.
Details
Result Code: K_FAIL (0x80004006)
Read more
Hey everyone,
My company is looking at expanding to 6 employees, and where thinking of using sharepoint ticket tracker for all employees throughout the company. I'm looking for a simple to install Issue Ticketing system to improve record keeping and the efficiency of the company. Would this software be suitable?
Read more
Hey techyv,
I have a task I need a hand with. I have been requested to do a translation for a 600 page technical manual in Framemaker linked to EPS batch files. I haven't found a way to translate EPS files without handling them one by one. Is there any kind of filter or even software to make this task easier?
Read more
