Archive
I just got my Sun box from eBay with Solaris but now I am unable to connect via Hyper Terminal to Solaris which cannot properly boot up. I have spent so many hours to fix this problem but I could not resolve this issue.
You can see the attached error image below so please provide helpful solution.
Any help would be greatly appreciated.
HyperTerminalnull_modem - HyperTerminal
Checking Memory:...
Read moreHello,
The following fatal error occurred during the installation of Corel Draw Graphics Suite X5- Service Pack 3 Update.
The message shows your update has been installed with the fatal error during installation.
What should I do now?
Can I get proper solution and instructions to fix this issue? I would be grateful to you.
Thanks in advance.
Corel DRAW Graphics Suite X5-Service Pack 3 Update
Your update has been installed
150_langen.msp—Fatal error during installation.
Read moreHello,
I currently downloaded my Corel Draw Graphics X5 Service Pack 3 but when I attempted to install this program the following error displayed-All having to do with .rbf files in the Config.msi directory.
How can I successfully install this update properly?
Have any idea to fix this issue?
I will wait for your best suggestion.
Error 2203.Database:c:WindowsInstaller5005d29.ipi. Cannot open database file.
System error-2147287035.
Read moreHello,
Recently, I installed the latest version of avast antivirus on my PC using Windows 8 Operating System but the following error appeared to uninstall this app because it is not compatible with Windows 8 OS.
I tried to manually uninstall this app but the error still displayed.
Have any idea about this problem?
I extremely need your help.
Thanks in advance.
Windows 8 Setup
What needs your attention
The following things need your attention before you can continue the installation.
Avast! Antivirus Manually uninstall
Uninstall this app now because it isn’t compatible...
Read moreHi experts,
I downloaded McAfee Internet Security as a trial and it is working fine but when I try to activate to get automatic updates the following error message displays.
How can I remove this error without having any trouble?
Can I get full instructions to activate this software? I really need your assistance.
Thanks in advance.
McAfee
Activation Unsuccessful
Install.exe - Application Error
The instruction at “0x6240cbdd” referenced memory at “0x6240cbdd”. The memory could not be “read”.
Click on OK to terminate the program.
Read moreHello,
Recently, I got the following error message when I uninstalled McAfee and installed Norton 360 and attempted to open Outlook. What is the problem?
How can I uninstall the add-in properly so that I may run my program?
I would appreciate your help.
Microsoft Office Outlook
The Add-in “McAfee Anti-Spam”
(c:PROGRA~2mcafeemskmskolplg.dll) cannot be loaded and has been disabled by Outlook.
Please contact the Add-in manufacturer for an update.
If no update is available, please uninstall the Add-in.
I bought a wireless printer Brother DCP-J385W to use with my laptop and desktop computer. I have installed Windows 7 on both systems.
I can use printer properly with my desktop computer but I can’t use it properly with laptop however, I am able to install everything except the driver.
The following error message displays saying “Printer driver was not installed”. What could be the cause of this error?
I really want assistance to resolve this matter.
Thanks in advance.
Add Printer
Printer driver was not installed. Operation could not
be...
Read moreHello,
I am trying to start Farm Ville application which requires Adobe Flash Player but it displays as crushed as you can see in error image. I reinstalled the Adobe Flash Player but the same error displayed.
How can I fix this annoying error message without having any issue?
I need your help. Thanks!
The Adobe Flash plugin has crashed.
Send crash report
Farm Ville Adobe Flash Loading Error
Read moreHello,
I am getting the following error message after downloading and installing CS6 Master Collection trial.
I am unable to open any program. I really need some help to fix this application error.
How can I solve it?
Have any idea about this?
Thanks in advance.
CS6ServiceManager.exe – Application Error
The application was unable to start correctly (0xc000007b). Click OK to
Close the application.
Read moreHi,
Recently, I downloaded Creative Suite 5.5 Design Standard and I attempted to install this software I got an error message at the end of the installation.
I have reinstalled the software and restarted my system but I could not solve this problem.
How can I fix it easily?
Thanks for help.
Installation Status
Your installation encountered errors.
Please try restarting your system and installing again.
Exit code: 7
……………………… Summary…………………………………………………....
. 0 fatal error(s), 73 error(s), 70 warning(s)
WARNING: DW024: The payload:...
Read more
