Archive
Hello Techyv Guys,
I need to know about creating the custom base ADMX file,
Please do the needful for explaining the process of generation ADMX template.
How to have multiple .admx files to display within a single category node in the Local Group Policy Editor.
Thanks & Regards,
David Scecere
Read moreHi All,
I am using Internet Explorer 8 and id trying to view IP camera through it, which says to install ActiveX for IP camera, even after installing the same, I am unable to view the same.
Is that the problem with IE 8, Please help me by providing a solution.
Thanks, David Shawn
Read moreHello Friends, Is there any program to send sms via Blackberry simulator. I am really not getting how to do that.
Does simulator really sending the sms to a recipient, Please advise in this regard.
If it is possible, Please provide me the details of the program that will help me to achieve it.
Dave Tuttle
I need know about how to include a video (in flv format) in a form using javascript in bizagi,
Please do the needful for explaining the way to implement this requirement in Bizagi,
If JavaScript coding can be provided that will be very helpful.
Thanks in Advance,
Dana Robin
Read moreI want to monitor JVM SNMP Ubuntu server that runs multiple Java processes, each of the Java process is independent & will have different SNMP counter.
I am searching for a simple monitoring tool that will ask the SNMP manager on that host without knowing port for each Java process.
Please advice.
Read moreI have a Gigabyte GA-P55A-UD4P ver. 1.0 motherboard and my problem is, whenever I play a video using my browser which is a Firefox, the sound randomly goes on and off.
And when it totally turns off, a reboot will fix the problem and then after a while, the same thing will happen. Is this an issue with my browser or with my motherboard itself?
Where can I find the drivers for my motherboard as I lost the disk that comes with it when I purchased it.
Read moreHi,
When I log into domain, the below mentioned error message is sowing up.
User Environment
Windows cannot load the locally stored profile. Possible causes of this error include insufficient security sights or a corrupt local profile. If this problem persists, contact your network administrator.
Please help me to get out of this problem.
Thanks in advance.
Read moreHello,
Script to add Domain Admins into local administrators group.
Any help with a script that can achieve this?
Thanks
Read more
I get the following error message when I try to roll out a deployment using MDT.
Why do I get this error message during the process of deployment?
The error displayed as “Application Microsoft Install office 2010 - virtualized returned an unexpected return code”.
Please provide a solution to resolve this issue.
Thanks in advance.
Error message: Application Microsoft Install office 2010 - virtualized returned an...
Read moreHello,
I have installed Adobe Reader 9.5.0 but when I try to access documents the following error message displayed.
Why am I getting this weird error?
How can I resolve this issue as soon as possible?
Have any idea to fix this problem?
I want resolution.
Please help. Thanks.
Adobe Reader 9.5.0 Installer Information
Error 1325.Documents is not a valid short file name.
