Archive
I am trying to install a new software on my computer but it always shows an error. No matter what software I tried to install, it always failed. I don't know how to get rid of it. I tried installing the same software on another computer and it works so I am sure that the problem is on my computer. How can I fix it?
The error is:
Warning!
Your system administrator has disabled the option to install any software on this computer per company policy.
Read more
I am running Windows 7 Ultimate and I am trying to install Skype Click to Call but it always gives an error:
Skype Click to Call Setup
An error occurred while applying security settings. Users is not a valid user or group. This could be a problem with the package, or a problem connecting to a domain controller on the network. Check your network connection and click Retry, or Cancel to end the install.
Retry     Cancel
I tried installing under Administrator account yet it still failed. I don't know which security settings I am applying that is...
Read more
HI folks,
I got a document from my colleague, which has a peculiar font so I searched in google and downloaded the font. When I am trying, I got this error message. But I do install the font and it is in the computer. Do I need to download in windows folder? Or do I need to download in different location? I don’t know where to keep the folder? Guide me please.
Please check Madhura font is installed on this computer
Read more
Hello brainy,
My installation of JDK bundle and Android Studio went perfectly good. The problem triggered when I try to launch the application. No error was shown during installation. And the try to set variables with different values, no luck error remains the same. Help to find the solution. Thanks in advance.
Failed to load JVM DLL C:Progrm FilesJavajdk1.7.0_40jre.
If you already have a 64-bit JDK installed, define JAVA_HOME variable in Computer > System Properties > System Settings > Environmental Variables.
Read more
Hello tech savvy,
I want to install this Medmount studio in my system, I tried to install and it was smooth. After installation when I attempt to setup Medmount, the error triggered, saying setup cannot continue etc. While setting up the operating system I thought all the system components are installed. But now I think some are missing? Am I right or wrong? Do I need to install them again? Thanks for your help.
An error occurred while installing system components for Medmont Studio. Setup cannot continue until all system components have been successfully installed.
Read more
Hi there,
Absolutely no idea, what went wrong when I am playing a game. The Modern warfare is quite interesting, while playing I got this error popping again and again. After this message it is not allowing me to play the game further. So I followed the general method to solve this by restarting the system. But no use of it problem persists, any suggestions will be great.
Create2DTexture(diorama_dc, 4096, 1024, 0, 827611204 ) failed: 8007000e = Ran out of memory
Read more
Hi Whiz,
There is problem with the Flickr API, when I try to modify the existing file it producing some error. I also have the same problem with the lightroom plug-in too. What will be the better solution to fix it? So try to upload new photos and then I tried in the new one, but result is same error pops. Whizzes’ assist me where I am going wrong.
Can’t update this collection.
Flicker API returned an error message (function uploaded. Message filesize was too large)
Read more
Hi Professionals,
When I try to submit a form, which I was working to a SharePoint I got message. I don’t understand about the rules were not applied. I have authentication to access this form and SharePoint. I rechecked the username it was correct. What else need to be done to correct this error? Your help is appreciated.
InfoPath
Your user name cannot be verified because the form's security settings do not permit it.
Error occurred during a call to property or method 'get-UserName'.
Read more
Hi all,
When I am trying to download or install any application from USB disk an error occurred. This happens when I am trying to transfer data from the system to USB disk. So Absolutely I am not able to access the USB disk. How to solve this error? I need to configure the connection to USB disk or it is set default? Help Please.
Error has occurred!
Read more
Need to buy laptop, nothing special and no big budget available, looked at two HP Pavillion 15 Ci3 8GB 1 TB and other one Toshiba Satellite C55 15,6 1TB 8GB. Which one is better? Have no idea about computers so need advice. Thanks:-)
Read more
