Archive
Hi.
I am in need of help in my Vault 2012 migration. I tried to migrate from Vault 2011 to 2012 but beforehand I also tried to backup the Vault. I log in as the Administrator and then select the Tools and then Backup. When all the process is done, it starts the validation but when done with it I am now facing an error "Failed to check pending changes from workgroup AUTODESKAUTODESKVAULT. Error a network related or instance specific error occurred while establishing a connection to SQLServer. The server was not found or was not accessible. Verify that the...
Read more
I am editing the backup settings on my Acronis True Image Home 2012. This is a preparation for performing backups afterwards. But I received a “The operation fails with error code 0x00040007. The specified file cannot be found.” The archive for the backup are placed on my external hard drive. How can I resolve this issue?
Read more
Hello TechyV Experts!
I need help on installing SQL Server 2012 with my Windows 7 32-bit PC. I tried logging in as the Administrator and then run the setup. Everything went well but when in the SQL Server DB Services, it fails with error “One or more command-line switches were invalid”.
I am in the current ql_config_repair_loc_wmi_provider_cpu32_1033 with a log stating “The SQL server feature 'SQL_Engine_Core_Inst' is not in a supported state for repair, as it was never successfully configured. Only from successful installations can be repaired. To continue, remove the specified SQL Server feature. ”
What should I do with the...
Read more
I'm having an issue with NFS games. I think its related to Nvidia card. One of my friend is also having the same issue with his nvidia card. The issue is, I cannot steer my car to the left side when i apply nitrous. It goes to the right side when i apply nitrous, but not left. It happened same with the latest game NFS RUN. It happened with my friend's computer (nvidia card) for NFS Hot Pursuit and Most wanted also.
Read more
Hello.
When trying to use Windows Update the error code 80040154 keeps coming up, I receive the message
Class Not Registered.
Windows Update
Windows could not search or new updates
An error occurred while checking for new updates for your computer.
Error(s) found:
Code 80040154 Windows Update encountered an unknown error.
Get help with this error
Most recent check for updates 4/17/2010 at 1:43 PM
Updates were installed 4/17/2010 at 2:17 PM
View update history
You received update For Windows and other products from Microsoft Update
Find out more about from Microsoft Update. Click here for details.
What a step should be done in order to correct this problem,...
Read more
We failed trying to install LD 7.3.1 on Server 2008 R2 in this morning.. We've looked thoroughly through the forum and applied all the tricks but still getting the 2869 error. We are logged in as Admin and running the MSI as Administrator, even tried via elevated command prompt.
Touchpaper Software key is in registry under wow6342node
IIS 6 Mgmt Compatibility is installed
All Roles Services installed as advised
IIS Authentication permissions set as advised
msi run via msiexec /i
AV software switched off
UAC switched off
Installing to default locations
The MSI log files show it fails here (full log attached):
Action 10:33:53: PublishProduct. Publishing product information
1:...
Read more
Some specific file in my drive F: is causing me trouble. The application's size is 1.08 GB, but it never opens. Though I don’t want that file there; so I need to delete it.
The hard part is: I can't delete it.
If I right-click on the file, Windows Explorer crashes. If I try to use the Delete key, Windows Explorer crashes.
An error produced in these situations:
Problem Event Name: AppHangB1
Application Name: explorer.exe
Application Version: 6.0.6002.18005
Application Timestamp: 49e01da5
Hang Signature: 423b
Hang Type: 0
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional Hang Signature 1: 5410a02a87cec8ffaeea9c4b037fc8ee
Additional Hang Signature 2: 06e5
Additional...
Read more
Hi guys,
I found my database works just fine on my hard drive but not on the server.
I receive the error:
'ActiveX Component Can't Create Object'
these are the line of code that triggers the error:
Set appWord = GetObject(, "Word.Application")
Any ideas for this?
I am owner of the server so unable to make any updates there.
Read more
Hi all,
Whenever I boot my laptop I found two Bad Image errors continuously but always at boot up I get:
C:Windowssystem32atiumdva.dll
And I also get a:
Failed to load CommonRes.dll at boot.
I’ve recently cleared a malware infestation and still having problems with the OS. When I try to run an update into Service Pack 2; then the installation times out.
Need your help.
Thanks in advance.
Read more
Hello buddy.
About couple of days ago, I started getting this every time I tried to run a program:
C:windowssystem32version.dll is either not designed to run on windows or it contains an error.
Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
The same error message emerged for every program but not for Microsoft Word and Windows Messenger. I made a system restore before three months and that result nothing. I use windows defender which makes a little result but after deleting it the error...
Read more
