Archive
It's been a long time i used DataContext Menu to set up a C#. 2010 application, and I’m already getting an error message:
"Error 2 'RpcSupport.Attestations' does not contain a definition for 'Receive_Date' and no extension method 'Receive_Date' accepting a first argument of type 'Rp.Att' could be found (are you missing a using directive or an assembly reference?) C:RPAttes.aspx.cs 94 16 RpSup.
att.dbml using the designer, but it doesn't have the "Receive_Date" column in the extension methods.
Please help me figure out how to fix this.
Read more
I wanted to display an email value in the EmailTB text control via ListView control, using this syntax below:
<div class="form_right_view">
<asp:Label ID="EmailTB" runat="server" Text='<%# Eval("Email") %>' CssClass="" Font-Bold="true"></asp:Label>
</div>
But when I try to use the value of the EmailTB.text in the code behind using this:
if (EmailTB.Text != " ")
string Username = Group.GetUserNameByEmail(EmailTB.Text);
I get the error: “Compiler Error Message: CS0103: The name 'EmailTB' does not exist in the current context.” Please help me fix this. Thanks!
Hi, I keep getting this error when I try to save an Incident.
This comes up every time I click on “Save”, whether I did update any field or not.
Though I don’t think it’s a BR, I’d appreciate if you can give me an easy way to disable all BR’s so I can be sure it’s not one. I’m thinking that SDE is trying to write a row that contains a sequence that is already in the _SMDBA_._TELDETAI_ table. Then again, I’m not quite sure. Hope you can help.
Error:
VBScript:BMC Service Desk Express
(1000) Record Not Saved:This was...
Read moreI tried to use the IF() operator as suggested on this article I found on stackoverflow. I knew this was what I needed exactly to finish the aspx page I’m working on, but when I did use it, and every time I tried, I just get this error:
Compiler Error Message: BC30201: Expression expected.
Can anyone tell me how to get past this?
Error:
Server Error in '/' Application.
Compilation Error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error...
Read moreHello to all TECHYV experts,
I am trying to make an account on MICROSOFT OFFICE OUTLOOK 2007, but it always failed on connecting to server. Please describe me brief way to create an account and use of Outlook 2007.
Thanks in advance friends.
Read moreWhat is a antivirus and how can it be transmitted and transferred to other computer? And also, what are the effects when it causes harm to a machine? Any ideas will be much appreciated. Thank you.
Read moreAfter successfully installing Fix-It Utilities 2012 an alert showed up with error “We have detected that you have Active Security installed on your computer.” But as I’ve checked on my computer, I couldn’t find any active security anywhere. What do I need to do now?
Read moreWhen successfully installed Hallmark Card Studio 2012 Bonus Software and clicked on any selection, I got an error “The connection to internet might be broken, please restart the application and try again.” My connection is working with other application. I also clicked on the Register Now button but I received the same message. I tried restarting my computer, but it doesn’t help. What should I do next?
Read moreI got an error with the result text of Autodesk Perform Status Enquiry. The Autodesk Network License Manager is also not working. The error says “adskflex: The desired vendor daemon is down. FLEXnet Licensing error:-97,121” How can I troubleshoot the problem?
Read moreI installed Autodesk Product Design Suite Premium 2012. After the installation, I activated it successfully. But I received “Activation Entry Error” when running the Inventor Professional and clicking on the Environments tab to re-activate it. Any fix for this? I posted the same exact error I am facing now.
Product Autodesk Product Design Suite Premium 2012
Serial Number
Product Key 78201
Registration - Activation Error (0015.111)
There is a problem with the activation code that you entered. Click on the following links.
Try again
Contact Autodesk
