Archive
When trying to connect my BlackBerry Torch through a USB in BB Desktop Manager, an error appears stating “No applications configured for synchronization”. I am not yet syncing anything; I just connected the BlackBerry Torch. But when I tried to sync Outlook, the same error appears. How can I set the synchronization settings properly? I need help. Thank you.
Intellisync
No applications configured for synchronization.
OK
Read more
Hi guys! I was trying to install Internet Explorer 9 on my Windows 7 64-bit PC.
But I always end up with error “Wrong version of Internet Explorer installer.” I am not sure if my installer is for 32-bit or 64-bit PC, but I downloaded it through Google Search.
How can I install IE9 correctly? Please help.
Wrong version of Internet Explorer Installer
This version of setup doesn't support your Windows system type (32-bit/64-bit).
Read more
Hi all of u i need help.
So please answer my question
Read more
I used Internet Explorer 9 and when visiting a website with web ads, I always received a pop up message that says “Some content is filtered on this site” with a button below to Turn off ActiveX Filtering. I am running Windows 7 64-bit PC. When clicking on the button to turn off the filtering, I did not see any effects on doing it. What can I do to manually disable the ActiveX Filtering? I need help. Thanks.
Use the button below to configure filtering options.
Read more
Dear All,
I own a HCL laptop with windows 7 installed on it. From some time it has started getting shut down without warning and then it only starts after waiting for some time. My temp details of the system are as follows. My temp details are attached herewith for your reference kindly guide me what to do.
Read more
Today I encountered a problem. I just downloaded the latest version of nRoute. I am trying to run this by installing it. But here I get an error message and that is:
"There is a problem with the nRoute registry. Please re-install the nRoute and start it again."
I have also visited some sites and forums to see if they have a solution to this problem but in vain. So, I need some suggestions on how to solve this issue. I will be glad for some insights.  Thanks.
Read more
Hi guys,
I’ve got a problem with my Sky Player on my Desktop. Whenever I try to run this, I just get an error. And that is:
'An error has occurred. If the problem continues check the Sky Player FAQs at skyplayer.com/help.'
I also signed up to the website, but I didn’t get any error code. So, I need some ideas for this issue. Any help is greatly appreciated.
Read more
I am trying to upload photos from Picasa 3.8.0 on my Windows 7 pc. I am trying to make my web albums. But I get some problems here. An error occurred here:
Error: com.google.photos.service.storage. PhotoService Exception: Error: 2 Account_Error at com.google.photos.service.storage.PhotoServiceException.mapStatusCode (PhotoServiceException.java:79)
I am using an 80GB account and I want to continue this profile. The major space of this account is free.
Any help is appreciated. Thanks.
Read more
I am facing some problems when I try to install the newest version of Live Essentials in my pc.
I tried it for several times.
But every time I just get a message and that is:
Couldn't install programs
Please try installing Windows Live programs again
An unknown error occurred
Error: 0x800b0003
Source: WaitForCatalog
It is very essential for me to run this software. So, please I need some advice for this.
Thanks!
Read more
I always use backup for files. For that purpose I am using PA. Due to some problems I encountered with my system I reinstalled Windows XP in my pc. I also downloaded the latest version of PA (12.01).
And for Legacy license I got a new registration code. After that I got some problems with my backup scripts. I also changed some scheduled tasks, but PA’s backup editor opens when a script starts. I need to run my scripts separately.
So, I’m in need of some help.  Thanks in advance.
Read more
