Archive
Try to go in control panel look for the settings for the power the reason maybe it is set on sleep mode for a couple of minutes you should turn it off that settings.
Read moreHi guys ,
Is there any software which will find you the chords after you import a song in to it?
Because I have lots of music files which have no names.
Can anyone help me with this?
Read moreWhenever I render for my RAM preview it stops after a few secs.Why is that ? And how can I fix it ?
Read moreHi In our company OEM is not installed.How can i collect the statistics using AWR and ADDM?And how can i tune the database.?pls explain.
Read moreHello guys,
I need some simple explanation about VPN,
what is it?
What is the purpose of VPN?
How can VPN help me?
Whenever I turn on my After Effect, an error pops up saying that couldn't execute OpenGL command. I really need it fixed.
What should I do ?
Read moreIf you have try to swapped with other power supply then it might be your processor is the problem. Have you try to clean up your fan inside your pc try first to remove it then clean it. If you haven't try yet because dust is sometimes the main reason why our pc get overheated.
Read more
Hi
I am working as a system admin.
Here we are using virtualized desktops.I am getting an error:
Vmware workstation unrecoverable error:(vcpu-0)exception 0x0000006 has occurred.
Thank you
Read moreI hope this will help you even a little. Try to remove your ram for a couple of seconds and put it back just be sure that it is mounted well, or may be the problem is your video card it might also untouched then try also to remove it then cling it well.
But you should try first the ram because a lot of possibilities might be a reason why is that happening.
Read more
