Archive
I am creating a PowerPoint presentation when I got this server application error that says the server application source file or item cannot be found or returned an unknown error. It suggested me to reinstall the server application.
I get this error when I was inserting PDF object to one of my PowerPoint slides. What should I do?
Is there another way of inserting PDF objects to PowerPoint?
Please send some help.
The server application, source file, or item can't be found, or returned an unknown error, You may need to reinstall the server application.
Read more
I am working with a large file in MS Excel 2010 and I have been working with this file for days already.
Whenever I work with formulas, my excel worksheet would work very slowly that it would take about half an hour for it to completely execute the compilation.
Then it would just stop responding. It also gave me the error message below.
Is my worksheet too heavy? What should I do?
Excel cannot insert the sheets into the destination workbook, because it contains fewer rows and columns than the source workbook. To move or copy the data to...
Read more
I have a WinZip file called RoboRealm which is 928KB. My WinZip Version is 1.7.22.1. But when I tried to open this 928KB file, it cannot be opened. It says it is not a valid archive. It is asking me to download the file again. Please send me valuable suggestions on how to deal with this kind of problem.
Any help is appreciated.
WinZip
Cannot open file: It does not appear to be a valid archive.
If you downloaded the file, try downloading the file again.
Read more
Can someone very knowledgeable help me fix my installation problems with my Mac Book? I cannot install Microsoft Office for Mac 2011 in my Mac Book. What should I do? After trying to reinstall it as what it suggested me, the installation still failed. I need your help.
There were errors with installation. You may want to try installing
again.
The installation failed.
The installer encountered an error that caused the
installation to fail.
Contact the software manufacturer
for assistance.
Read more
I am trying to update my iPhone to the latest iOS 5 but I am receiving error 3194. I am currently under iOS 4.3.5. I already downloaded iOS 5 IPSW Firmware but still receiving the same error. Kindly please send me some solutions to this. Thank you.
Read more
Hi Techyvs,
Is it possible to Rename File Extensions? Thanks & Regards Any help is of great use.
Sadah Yapsangco
Read more
I am running Active Directory in Windows Server 2000. But for some reason, I am receiving error stating that my Active Directory login attempt failed. I have two subnet works running. It both runs with internal and external switch. And both my Active Directory and Exchange server runs on DC.
I already install SharePoint Server Portal on other web server under the external subnet work. I switch the option for making a second external subnet in DNS GUI. But after doing that, the Active Directory suddenly stopped working. So I switch back to the default setting hoping that it can...
Read more
I am trying to migrate from Exchange 2003 to Exchange 2010. When I am about to complete the migration, and create signatures in OWA, I am receiving error: The text you typed is too long. Please shorten it and try to save it again. As far as I know, this is another issue of fixing registry in Exchange 2003 wherein we can set the maximum size limit for the signatures, but I could not locate the same settings in Exchange 2010. How can I fix this? Where can I find the settings for this? Thank you.
Read more
I am having this problem from the time I log on in the exchange server.  My Eudora for Mac failed to work with Microsoft Exchange. It says that the POP server has protocol error while checking the mails. I need solutions for this. Please help me resolve my problem.
Task Progress
Error while checking mail for <<Dominant>>:
I said PASS
And then the POP server said: - ERR Protocol error. 16
Read more
I have a jail broken iPad 3G S. I have Cydia and AppSync 4.2 installed on it. However, I am still getting an error 0xE8008001 when trying to sync applications. What is this error all about and how can I fix it? Does anyone have a suggestion? Thanks.
Read more
