Archive
I am trying to create a new webpage on Windows 7 computer using localhost. I am trying to access the default page of the webpage but I am getting the error as mentioned in the picture. I tried to delete the mentioned line by MSDN but no results. Can anybody help me fix the issue?
msdn error
Read more
I am trying to use OUTLOOK 2007 and PCitunes v8 on my windows XP desktop. I can successfully synchronize my 1st Gen iPhone OS v3.0 but an error message pops up after the "merge" (not replace) synchronization is done. It wants to reconcile Outlook vs. my iCal. I'm only syncing my calendars. When I click the first occurrence of use iPhone" to reconcile which calendar (Outlook vs. iPhone) is correct, the error message appears. iTunes then doesn't allow me to correct any (other) calendar conflicts but gives me error message "Unable to retrieve conflict information from the sync server."
Read more
When I am trying to configure virtual directory against my server that is running IIS-7.0 using "Configure Web Synchronization Wizard", I am getting an error message “IIS was not found on the Web Server. Please specify a computer name that has IIS installed.” How will I fix this issue?
Read more
 I am trying to use the asterisk server for the first time. I have got a project to build a dialer based on asterisk server. But I started getting errors while using asterisks server. While using the “asterisk” I am getting error:
 dahdi-linux-2.4.1.2-1_centos5.x86_64 from asterisk-current has depsolving problems
   --> Missing Dependency: dahdi-firmware is needed by package dahdi-linux-2.4.1.2-1_centos5.x86_64 (asterisk-current)
 Error: Missing Dependency: dahdi-firmware is needed by package dahdi-linux-2.4.1.2-1_centos5.x86_64 (asterisk-current)
Read more
When I am trying to start the dovecot, I can’t see any leading errors in the file /var/log/mail.log, But when I start checking out the different details from different files, I do see errors in /var/log/syslog stating: init: dovecot main process (xxx) terminated with status 89. Is there any idea how to resolve the issue?
Read more
The Message "No Connection Check Signal Cable" always shows at the monitor everytime i start my desktop computer.
The image below shows the error message i receive from my monitor.  I already checked the connection of the cable for the monitor and it is connected perfectly and the CPU is running. What can be the problem? My monitor is a samsung CRT
Read more
When I try to access com.sun.org.apache.bcel.internal.generic.AALOAD it returns as an error.
The Error is as following:Access Restriction: The type AALOAD is not accessible due to restriction on required library: C:Program Files(x86)Javajrelibrt.jar.
So my question is: how can I un-restrict the restrictions the rt.jar may have, so that my program can run properly, or is there another problem that is preventing me to access the file?
Many thanks!
Read more
Last month, My PC work fine, But this month My PC doesn't work fine. How can i maintain my PC performance?
Read more
I am using Microsoft Windows XP Service Pack 2, Also have Internet connection, but after 2/3 months of new windows setup i have got a message for windows license validation. You may be a victim of software counterfeiting, This copy of windows did not pass genuine windows validation. For that i am unable to work perfectly sometimes, now what can I do???
Thanks
Tom Cruise
Read more
I am getting this error message below.
I am using Magic Bullet LooksBuilder 1.4 plug-in with Adobe After Effects CS5 in Windows 7.
Is there a problem with my software version combination?
I read something about a video card issue.
Which video card should I use? Or, can I just update my video card driver?
I am new to video editing so please help on how to resolve the problem.
LooksBuilder SE
An OpenGL error occurred while attempting to load the frame (glTextImage2D: 1285).
Read more
