Archive
What other photo editing software can you suggest other than ADOBE PHOTOSHOP? What are the main difference of Adobe Lightroom and Adobe Photoshop in terms of usability and quality? Which is more User Friendly between the two? All replies will be highly appreciated! Thanks!
Read more
Do you think cloud computing is really economical, when it comes to our modern technology? How is the resource pooling relevant to the economical benefit of the cloud computing? It has been said that this cloud computing depends on the population metrics, how are they really related to the benefits of cloud computing?
Read more
Nokia introduced a cell phone with a series number of 6600.
It gets affected by a virus whenever we switch the Bluetooth on.
This virus was commonly found in every set of this series.
Why was this virus encountered?
And which anti-virus can protect the 6600 series from this particular virus?
What is the behavior of this virus?
Read more
IF U START DOWNLOADING AND YOUR NET GO'S OFF, HOW CAN YOU FIND THE FILE & WHERE?? SHOULD U START AGAIN FROM FIRST IF NOT,THEN WHERE U CAN FIND THAT? WHAT IS THE NAME OF THAT SOFTWARE????
Read more
This picture shows a kinect game and it is a beta version as well. Which concept of DISCRETE MATHEMATICS is used behind making of kinect and why?
From how far can this beta version game detect our motion?
Read more
In making some business aplications, emails,feeds, and calendars. That provides an easy to use, the one that has the capability to get my work done quickly. That has almost everything. What is the best thing to use for this kind of project, is Lotus notes user friendly or easy to use? How can I use that one?
Read more
There are some shortcuts created in some files in this USB but they are not detected as virus, can they be recovered?
And why are they not detected as virus when affected by a virus?
Read more
I can't find how to install Need For Speed World in Linux using Wine. Can you help me please? I want to play it really because it's awesome and Free, but every time I try to run it through Terminal I have some .NET errors on the screen.
Process to install Need For Speed World in Linux using Wine
Read more
I am using blackberry8830 mobile handset and I have a Sony Vaio net-book.
Last night I wanted to transfer a data from my phone to laptop and I activated both of devices but when I am trying to sending data from my blackberry to my laptop and its saying cant sending the file to my laptop .
So how I will solve this problem?
Read more
This is he audio feature comparison of html5 between different browsers.
Safari 3.0 does not support the audio format of Ogg Vorbis, why is that so?
Does new version of Safari will support any new features of html5 which were not supported in the previous versions?
Read more
