Archive
When and where should I enter the Record Format file with PAGNBR field to obtain the page number in Printer File? I have already declared the keyword PAGNBR in the program described printer file which is the PRTF. Is there anything else that I need to do?
Read moreI am using IBM CoZBATCH utility program and I am receiving error 255 while trying to transfer a CSV file to the network drive using FTP. How can this be resolved?
Read moreI would like to transfer EMC CLARiiON from one website to another. How can I make this possible? Do I have to stop the MirrorView before moving or what do I need to perform this? Please help.
Read moreCan anyone cite some steps or a way to locate any resources that could help me to implement a secondary DR site using Cisco gear with HSRP (Hot Standby Router Protocol)?
Read moreHow can we track the date and time of the last patch installed on my SQL Server so that I can be able to track whether the installed patch is an update or a hotfix?
Read moreMy test system has a different IP address as to my production. I am getting a QSYSOPR message queue from my test system to the production system. How can I fix it?
Read moreDoes the Lotus Note cross certification conforms TDES encryption strength and confirm whether the ciphertext form is encrypted with a KEK (Key Encryption Key)?
Read moreWhat are the changes a batch job creates in an AS400 system and is it possible to stop the job instantaneously in the AS400 system?
Read morePlease suggest an IPv6 transition technique, other than dual-stack and tunneling methods, that is beneficial for a large enterprise?
Read moreCan anyone explain the steps for generating an AS400 Spool file report so that I can send it for testing?
Read more
