I want to ask your opinions on what is the best internet provider here in the Philippines? Between 2 PC, I want to have a reliable, unlimited access, the provider should have a bandwidth on demand service because sometime we upload many files especially the end of the month. Forward your suggestion please.
What’s the best provider in PHILIPPINES (point to point connection)
Hello Ronaln,
I recommend a Smart Broadband. It is the best internet provider in the Philippines. It is proven and tested by many users. Smart broadband is fast and reliable with up to 1 mbps. It will only cost you One Thousand Pesos monthly. You can use WiFi or router to be able to use both PC's.
And even if you use WiFi or router, it will not lag or slow. It is very consistent. In fact, Smart Broadband is what I am using now and it never fails me. Almost all of my friends also use Smart bro as their internet provider.
You can visit their site to be able to know more about their services. I can assure you that you will never regret if you use it. And the best thing about smart is that they have a very polite customer service. Here is their website
I hope it helps.
Zorian
Another reliable internet connection is GLOBE DSL. They have several packages you check out on their website. I've been using their 2 MB service and I'm getting the promised speed.
